Re: winter cover or not
[Re: Phantom364]
#10282
09/17/10 05:48 PM
09/17/10 05:48 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
I srinkwrap down to about an inch above the toe rail. I would get a custom cover but they are very big and heavy to store during the summer. The srinkwrap and wood frame get recycled.
I do this mostly so I can work on the boat during the winter and to cut the UV down by half during the year on my expensive running rigging.
[Re: Phantom364]
#10286
09/20/10 01:32 PM
09/20/10 01:32 PM
Posts: 393 Rockwood, MI, USA
Russ Atkinson
Rockwood, MI, USA
Our mast is removed and is kept on deck. Above the must, mounted to the mast support framework we run a 2 x 4 backframe down the length of the boat. 1" electrical conduit runs from the lifeline station bases up through the backbone. We use a 20' x 32' heavy duty gray nylon tarp (like the blue nylon tarps sold at Home Depot only heavier) that we use to cover the boat. Both ends are left open I have easy access from the stern - the tarp covers the sides down almost to the boot top. There is plenty of air flow under the tarp but the snow, rain and ice are kept off of the deck. The current tarp has been used for 6 years and has at least 1 or 2 seasons left on it. I paid less than $100 for it when I bought it. - shrink wrap costs $100 - $400 per year, custom covers cost ???. I put the savings into upgrading to hi-tech mains Although some store the boats with mast up, I recommend storing the boat with the mast down
[Re: Phantom364]
#10287
09/20/10 02:17 PM
09/20/10 02:17 PM
Posts: 83 Waukegan, IL
jhoskins
Waukegan, IL
Russ,
Sounds like a nice setup. I am going to build the same cover this year. I have stored inside, but this year I decided to save $$ and store outside mast down.
Question.. Why the backbone above the mast? Could you use the mast as the backbone of the frame?
John Madcap 358
44
guests, and 14
