977,679 Dacron Main
163,119 Ananda's Refit
Page 2 of 6 1 2 3 4 5 6
Re: Hull 474 on eBay [Re: Crusader586] #9677
06/13/10 02:07 PM
06/13/10 02:07 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
you can always have two ... You will be suprised at how easy it is to fix everything the second time around.
Re: Hull 474 on eBay [Re: Cap'n Vic] #9922
07/29/10 02:32 PM
07/29/10 02:32 PM
PNW
lakesailor Offline
lakesailor  Offline
PNW
Here is clean J/30 located in Nanaimo, B.C. Not many for sale in the NW....
http://www.buysell.com/root/detail/...mfortable_10.aspx?gok=Sailboats+23+to+31
Re: Hull 474 on eBay [Re: lakesailor] #9932
07/30/10 12:51 PM
07/30/10 12:51 PM
Maryland, USA
Bob Rutsch Online content
Bob Rutsch  Online Content
Maryland, USA
Not many for sale at $32.5K either.
Re: Hull 474 on eBay [Re: Bob Rutsch] #9933
07/30/10 01:16 PM
07/30/10 01:16 PM
PNW
lakesailor Offline
lakesailor  Offline
PNW
Agreed....it seems anything over $ 25K is slow to move.
Re: Hull 474 on eBay [Re: lakesailor] #9934
07/30/10 01:38 PM
07/30/10 01:38 PM
Maryland, USA
Maryland, USA
..and when they do move it is usually for less than $20K.
KAOS Hull #295 For Sale on eBay [Re: Rhapsody #348] #10481
11/11/10 08:30 AM
11/11/10 08:30 AM
Rhapsody #348 Offline OP
Charlie Stoddard sent me the ebay link for this. This boat is literally in my back yard - at the marina around the corner from where I live. It's been on the hard since 2002 and needs some TLC. Anyone interested in a second J/30 as a project or parts? Bids close 11 Nov 5pm EST.
Re: KAOS Hull #295 For Sale on eBay [Re: Rhapsody #348] #10489
11/12/10 07:22 AM
11/12/10 07:22 AM
Well Nemesis, Falcon & Rhapsody teamed up but got outbid on eBay to buy KAOS. I stopped by at lunch time Weds and snapped a few pictures. They are shared on my Picasa album with a select few here.
Brand new 3/4" shaft, but no prop
TSP number stamped on transom with spider web cracks indicate the transom is saturated and need to be recored
Open holes on aft cabin require recore work there. The companionway cover has about 3/4" gap with hatch boards allowing rain to enter the cabin. Significant water damage occured inside.
Standing water on teak deck. Water line evident inside up to settee level. A 2" hole has been drilled through hull in bilge sump to drain boat. The teak looks like it would need to be ripped out.
The rig looked ok, as did spars. There was a Hall quick vang below decks. It doesn't appear this boat has the spreader bar fix.
The culprit for wet core - there is a visible gap in the engine exhaust through hull. Evidence of wet core on stbd side below waterline, transom, and stbd side just fwd of transom to the deck level.
Stbd aft spider line cracks indicate wet core froze.
Stbd aft looking forward. Note that core has been crushed and the hull is deformed where the boat has been resting on the poppet.
Re: KAOS Hull #295 For Sale on eBay [Re: Rhapsody #348] #10796
12/16/10 04:27 PM
12/16/10 04:27 PM
Marblehead, MA
dbows Offline
dbows  Offline
Marblehead, MA
That propshaft is worth more than the whole boat.
Re: KAOS Hull #295 For Sale on eBay [Re: Rhapsody #348] #10812
12/20/10 11:24 PM
12/20/10 11:24 PM
Wilton, CT
B
bemusv2 Offline
bemusv2  Offline
B
Wilton, CT
I stopped in and saw the boat in Portsmouth on Saturday and the extensive interior damage and obviously rotten core would lead me to agree with Dave. It could probably be fixed up to fighting shape but would wind up being more expensive than buying a 30 in better shape.
If the spar is in good shape that might be worth something as well.
Re: KAOS Hull #295 For Sale on eBay [Re: bemusv2] #10813
12/20/10 11:45 PM
12/20/10 11:45 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
0 registered members (), 41 guests, and 0 spiders.
