Water accumulation in false bilge
#10459
11/04/10 03:42 PM
11/04/10 03:42 PM
Posts: 10 Florence, Al. USA
Steve Blazier
Florence, Al. USA
For years I have tried to figure out where the water was coming from - rain? propeller shaft seal? leaking traveler track? what? I recently moved my boat to a better protected marina and docked the boat into prevailing wind direction. The water stopped and the amount of dewatering (pumping) of the false bilge has dropped to little or none. What changed - my stern does not receive any wave action and on closer inspection, it appears that the exhaust seal on the transom is cracked. On next haulout, I will repair that, but for now, I'm much happier without having to go to the boat and pump out 1 or 2 gallons each week.
steve
51
guests, and 0
