Whale Gusher Galley Pump Mk II
#11238
03/04/11 12:53 PM
03/04/11 12:53 PM
Posts: 678 Maryland, USA
Bob Rutsch
Maryland, USA
I disassembled the foot pump from the head to see why it is not working. It's 20+ years old, the one at the bottom, Mk II (or Mk 2) ( Whale Gusher Galley Pump Mk 3 & Mk 2 exploded). The intake and outlet valves looked fine, the rubber diaphragm was a bit distorted but still pliable with no tears or holes. I adjusted the diaphragm and reassembled, but it's still not pumping. A spares/rebuild kit consisting of rubber o-rings, valves and diaphragms is about $30 US, while a replacement Mk 3 from discounters is $100. I like saving money and don't mind the work, but I wonder if the rebuild will do the trick or if I should save the trouble and splurge on a new one. Anyone used this repair kit? Any experience as to whether the Mk 3 is a drop in replacement and will hold up for another 20 years?
Re: Whale Gusher Galley Pump Mk II
[Re: Bob Rutsch]
#11245
03/04/11 09:39 PM
03/04/11 09:39 PM
Posts: 111 Bellevue, WA, USA
R II
Bellevue, WA, USA
The deformed diaphram and perhaps one of the other seals is likely sucking air. I have rebuilt both the galley and the head pumps with mixed results. The first one I did was great, however the second one leaked for some unknown reason and I could not get it to stop and ended up finding a replacement at a used gear chandlery. During the rebuild, it was pretty tricky to get everything to line up with the spring in the middle of the body trying to push everything apart. Since I am pretty thrifty, if I had to, I would try the rebuild again.
AC
[Re: Bob Rutsch]
#11334
03/14/11 12:00 PM
03/14/11 12:00 PM
Posts: 45 Key West, & Charlotte, NC
lumpy
Bob,
I was looking at the equipment from hull #420 yesterday. Ted has two of the pumps and they are supposed to be in working condition. This might be another alternative. You can reach him at tkaper6862@aol.com or through the for sale section of the Forum.
LUMPY
Scott Davis Night Nurse #363
48
guests, and 13
