978,030 Dacron Main
163,237 Ananda's Refit
Trailer Dimensions #11585
04/26/11 10:36 PM
04/26/11 10:36 PM
Denver,CO
hull214 Offline OP
hull214  Offline OP
Denver,CO
I am soon to be a new owner of a J30. I am getting quotes on trailers and also trying to find a used trailer that will work.
I have estimated the distance from the front bow stand to the trailing keel edge at 17'.
Can anyone confirm this actual measurement. I want to make sure the keel ends up in the middle of axles no matter what trailer I end up with.
Thank you
Troyrock@earthlink.net
Re: Trailer Dimensions [Re: hull214] #11588
04/27/11 07:40 PM
04/27/11 07:40 PM
Vancouver, BC. Canada
Patrick Peters Offline
Troy
If you can wait until Friday I can get you some measurements from my trailer.
Patrick Peters
Ariel #374
Re: Trailer Dimensions [Re: Patrick Peters] #11589
04/27/11 10:53 PM
04/27/11 10:53 PM
Denver,CO
hull214 Offline OP
hull214  Offline OP
Denver,CO
That would be great, thank you!!
Re: Trailer Dimensions [Re: hull214] #11590
04/29/11 01:05 AM
04/29/11 01:05 AM
Troy
I have a three axle trailer, the center of the front axle is 15'4" from the ball, and the leading edge of the bottom of the keel is 9" behind the front axle. this gives me about 1,000 lb of tongue weight so the trailer won't sway going down the highway. My front set of stands are 8'8" from the bow of the boat, the second set are 9'9" behind the first and end up just behind the keel. the back stands are at the back of the trailer and my boat hangs three feet past. the keel sits just above the axle hight which is about 14" off the ground. The stands are all 60" high measured from the ground with the pads adjusted all the way down. the pads have 2 feet of vertical adjustment which is more than enough.
I don't know if any of that makes sense, just let me know if you need anything cleared up.
P1040334.JPG [655.76 KBytes] - (324 downloads)
Copy of P1040368.JPG [1035.74 KBytes] - (336 downloads)
Copy of P1040363.JPG [257.85 KBytes] - (304 downloads)
Patrick Peters
Ariel #374
Re: Trailer Dimensions [Re: Patrick Peters] #11592
04/29/11 10:35 AM
04/29/11 10:35 AM
Denver,CO
hull214 Offline OP
hull214  Offline OP
Denver,CO
Thank you very much, I appreciate you taking time to do this!
Re: Trailer Dimensions [Re: hull214] #11593
04/29/11 05:27 PM
04/29/11 05:27 PM
PNW
lakesailor Offline
lakesailor  Offline
PNW
When I get home tonight I will also post some pictures and take some measurements of my trailer_..
0 registered members (), 38 guests, and 1 spider.
