977,538 Dacron Main
163,067 Ananda's Refit
Cushion cleaning #11881
06/06/11 06:11 PM
06/06/11 06:11 PM
Portland, OR
Raucous Offline OP
Raucous  Offline OP
Portland, OR
OK Team,
The cushions are a little mildewed after the winter. Do I take them to a dry cleaner or just go after it with a shop vac? Any strong opinions here?
Marc Peterson
Raucous #391
Re: Cushion cleaning [Re: Raucous] #11886
06/07/11 09:11 AM
06/07/11 09:11 AM
RI
Bob Rude Offline
Bob Rude  Offline
RI
Around here many of us have the cushions picked up by a dry cleaning company in the fall. They store the cushions for the winter and then clean them in the spring before delivering to the dock. The cost for this service and the cleaning is about $125.00. Personally, I would never leave my cushions on the boat during the winter. As it is, I wipe the boat interior down with Fantastic each spring just to make sure that everything is clean before the cushions are delivered.
Bob Rude
Mmmmm #352
Re: Cushion cleaning [Re: Raucous] #11887
06/07/11 11:20 AM
06/07/11 11:20 AM
Oxford, MI
Conundrum Offline
Conundrum  Offline
Oxford, MI
In my rehab of 484 i removed the covers and spot cleaned with SHOUT then put them in the washer on gentle with Tide
Air dryed. Very satisfied with the results
She sat 6 years with a wet bilge
Now clean and fresh
Re: Cushion cleaning [Re: Raucous] #11888
06/07/11 11:36 AM
06/07/11 11:36 AM
Portland, OR
Raucous Offline OP
Raucous  Offline OP
Portland, OR
Both of you have some good ideas. I am not sure about taking the covers off mine. They actually have big metal staple-like buttons through them. It may be time to replace them though as the metal seems to be rusting.
Thanks for the ideas! What a great forum for help on this boat.
Marc Peterson
Raucous #391
Re: Cushion cleaning [Re: Raucous] #11894
06/07/11 02:32 PM
06/07/11 02:32 PM
Oxford, MI
Conundrum Offline
Conundrum  Offline
Oxford, MI
I replaced the metal backers with plain buttons
My cushions foam was worth saving
The trick to the button and tuck is a hook that can close, or you can use a piece of tape. Then you can just tie on the plain buttons on the back
Good luck
Re: Cushion cleaning [Re: Conundrum] #11896
06/07/11 06:40 PM
06/07/11 06:40 PM
Portland, OR
Raucous Offline OP
Raucous  Offline OP
Portland, OR
Seems like a questionable design anyway with the rusting metal on the cushions. I kinda like the idea of having a service clean them though. Seems like someone must have better equipment than I do for getting the winter out of them.
Marc Peterson
Raucous #391
0 registered members (), 36 guests, and 0 spiders.
