Cushion cleaning
#11881
06/06/11 06:11 PM
06/06/11 06:11 PM
Posts: 14 Portland, OR
Raucous
Portland, OR
OK Team, The cushions are a little mildewed after the winter. Do I take them to a dry cleaner or just go after it with a shop vac? Any strong opinions here?
Marc Peterson Raucous #391
Re: Cushion cleaning
[Re: Raucous]
#11887
06/07/11 11:20 AM
06/07/11 11:20 AM
Posts: 203 Oxford, MI
Conundrum
Oxford, MI
In my rehab of 484 i removed the covers and spot cleaned with SHOUT then put them in the washer on gentle with Tide Air dryed. Very satisfied with the results She sat 6 years with a wet bilge Now clean and fresh
[Re: Raucous]
#11888
06/07/11 11:36 AM
06/07/11 11:36 AM
Raucous
Portland, OR
Both of you have some good ideas. I am not sure about taking the covers off mine. They actually have big metal staple-like buttons through them. It may be time to replace them though as the metal seems to be rusting.
Thanks for the ideas! What a great forum for help on this boat.
[Re: Raucous]
#11894
06/07/11 02:32 PM
06/07/11 02:32 PM
Conundrum
Oxford, MI
I replaced the metal backers with plain buttons My cushions foam was worth saving The trick to the button and tuck is a hook that can close, or you can use a piece of tape. Then you can just tie on the plain buttons on the back Good luck
[Re: Conundrum]
#11896
06/07/11 06:40 PM
06/07/11 06:40 PM
Raucous
Portland, OR
Seems like a questionable design anyway with the rusting metal on the cushions. I kinda like the idea of having a service clean them though. Seems like someone must have better equipment than I do for getting the winter out of them.
39
guests, and 1
spider. |
