Throttle assembly
#12008
07/01/11 03:22 AM
07/01/11 03:22 AM
JBro
OK - does anyone know how to disassemble the throttle assembly? Better yet, anyone know how to get rid of "play" in the assembly? Mine has the red ball on end of throttle lever and a black pull out lever for neutral. I pulled the lever, the neutral pull-switch in the middle, and I can't tell if I'm missing some set-screw someplace or if mine is simply fused in place. Does the neutral pull-out lever/switch hold the exterior assembly in place? Any tips/suggestions much appreciated because I have way too much play in the mount - as if it needs to be tightened on one or both sides to clamp it down onto the lazarette wall. Caveat: I started this project way too late in the day... fatigue and a few Pacificos *could* have shortened my patience. Thanks, - Jeff
- Jeff J/30 #426 - Watusi
Re: Throttle assembly
[Re: JBro]
#12009
07/01/11 08:12 AM
07/01/11 08:12 AM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Jeff - I assume you are referring to a throttle lever that looks like this: It is probably fused in place if it hasn't been lubed. Remove the lever from the bulkhead and disconnect the cables. Disassemble the entire assembly and make sure you don't loose the spring and ball bearing that acts as a detent. Clean all the parts get all the corrosion off the rod that goes through the center that the black knob screws into. This must be lubricated well with grease when you reassemble. You'll see when it is apart how the black knob engages the shift lever or disengages so you just move the throttle cable. The throttle cable moves the same direction when you increase throttle position in either forward or reverse.
[Re: Rhapsody #348]
#12010
07/01/11 11:18 AM
07/01/11 11:18 AM
JBro
Awesome - thanks Bill. That makes sense. While looking at the external piece and the gears around the spindle, there's a fair bit of oxidization/corrosion. It's fused pretty tightly so I'm guessing not much grease was used.
Thanks again! - Jeff
39
guests, and 1
spider. |
