• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Will not start
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97873
Northwest one-design 55185
Other J/30 Sailboats For Sale 29385
Comment Here - Draft Potential Rule Changes for 2009 28767
2010 Class Registration & Dues 28128
Rhapsody Transom Re-core and Other Areas Too 27235
J30.org Web Page 20716
2009 J/30 North Americans at Cedar Point YC 19505
J/30 Midwinter and Mardi Gras Regatta 14944
Southern Straits 13271
Forum Stats
595 Members
27 Forums
2618 Topics
Page 1 of 2 1 2 >
Topic Options
#12136 - 08/02/11 08:27 PM Will not start
Groovin Offline
Loc: St. Margarets Bay, Nova Scotia
Unbelievable the two biggest local regattas coming and the motor will not start. It was sucking half the fuel out of the filter on the engine now and then and stalling requiring a reprime and then it would be fine. Put new fuel pump on believing that it was the issue. Shut it off after one race and week later turns over runs for 3 seconds and dies. I changed the filter on the fuel water seperator (was very dirty and may have been the original issue), changed the filter on the motor added good fuel, pumped out bottom layer of fuel that was dirty in the tank, cleaned the injectors, checked the exhaust elbow. All seems to be fine. The engine sounds like it is trying to run when the starter is cranking it over but just dies when you stop. Checked that there was fuel coming out the high preasure lines at the injectors, how much preasure is supposed to be there? Played with the fuel shut off which seemed to end any good sound when cranking it over which sounds like it is not half on. Any ideas??
Top
#12139 - 08/03/11 08:26 AM Re: Will not start [Re: Groovin]
Rhapsody #348 Online   content
Class Co-President
Loc: Portsmouth, RI
When you say you changed the fuel pump, was it the fuel lift pump on stbd side of engine, or the high pressure pump that feeds the injectors? My guess is that there is a problem somewhere between the inlet to the fuel filter to the inlet of the HP fuel pump, or bad compression (e.g. stuck valve or bad valve seat).
Try using a compression tester to make sure you have adequate pressure built up in the cylinders. Have the HP fuel pump bench tested at a diesel shop and while they're at it, check the individual cylinder timing. You should have very high pressure out of the HP fuel pump (don't have spec handy but I believe over 500psi). Have the injectors pop tested and see if the nozzles need replacement.
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#12141 - 08/03/11 09:16 AM Re: Will not start [Re: Rhapsody #348]
Groovin Offline
It was the lift pump. Took the valve cover off and valves seemed to work fine and do not know if the seat would be bad.
I have another mechanic coming and i will make sure he brings the tester. the preasure out of the HP pump is nowhere near that high, he put his finger over the line and it was squirting a bit past his finger. Injectors were checked by diesel shop. one time we were cranking it over and stopped he said he saw a spark come out of the intake. No fuel runs out of the return on the injectors when trying to bleed. Greg
Top
#12142 - 08/03/11 09:25 AM Re: Will not start [Re: Groovin]
Class Co-President
Loc: Portsmouth, RI
ok - sounds like the HP fuel pump isn't doing its job, or is fuel starved. You're also on the right path with the compression check.
Bill Kneller
Rhapsody J/30 #348
Top
#12143 - 08/03/11 09:43 AM Re: Will not start [Re: Groovin]
jhoskins Offline
Loc: Waukegan, IL
Just had my HP fuel pump rebuilt. My engine was blowing a lot of soot and hard to start. Its like a new motor! Ive been told that the new deisel fuel is hard on old fuel systems and to add a fuel additive to every tank.
John
Madcap 358
Top
#12145 - 08/03/11 04:23 PM Re: Will not start [Re: Groovin]
Groovin Offline
Just heard from the Stairs Diesel and he does not believe that he has to replace all the components inside and thinks it might have been putting out enough fuel. He is replacing all gaskets and is going to bench test. I'll put it in tomorrow night and see what happens. Still have the mech coming friday morning so i'll cross my fingers. He did say they are very hard to bleed sometimes but we had solid fuel coming out the high preasure pipe without air. Maybe it is starving on the low preasure side??? Thanks stay tuned!
Top
#12150 - 08/05/11 03:45 PM Re: Will not start [Re: Groovin]
Groovin Offline
Pulled head and found split piston. Now have to pull motor and send to machine shop to find anything else gone. Damn motors
Top
#12151 - 08/06/11 08:43 AM Re: Will not start [Re: Groovin]
Rambunctious Offline
Loc: New Orleans, LA
Sorry to hear that!
How much cranking did you do trying to get the motor started and did you shut off the raw water intake?
Cranking excessively with the intake open can pull water into the motor without enough pressure to eject it the through the exhaust and "hydrolock" the motor. Usually it will bend a connecting rod, but I suppose it could crack a piston.
Based on your description above, I was thinking fuel quality/delivery... Certainly not a
split piston.
Hope you get it sorted out quickly.
- Jason
Rambunctious #280
Top
#12152 - 08/07/11 09:32 AM Re: Will not start [Re: Rambunctious]
Groovin Offline
I tried it some when it was open but then shut it off to be safe. The motor ran for 5 seconds when we tried to get it started so it think the problem was there. No funny noises though!
Top
#12185 - 08/12/11 11:45 AM Re: Will not start [Re: Groovin]
Toy Box Offline
Loc: New Orleans, LA USA
There is no doubt you have air sucking somewhere, I recently had the same problem. I started with have the injectors re calibrated, then started at the fuel pump on the starboard side, one was tight, but just not tight enough. Then I moved to the injectors and bled them there. That was the problem. It can be quite frustrating, I know.
Toy Box
Toy Box
Top
#12192 - 08/15/11 12:25 PM Re: Will not start [Re: Toy Box]
Groovin Offline
One more question. The machine shop found a bit of rust on the exhaust valves. He is trying to preasure test the wet exhaust manifold. Is there any other way the exhaust can get water coming back? Not by me overcranking (which may of happened after it broke) but before? Causing the problem? Greg
Top
#12340 - 09/12/11 08:14 PM Re: Will not start [Re: Groovin]
Groovin Offline
Well all fixed. Number two piston split. Pulled the motor at the mooring without the head on it and dropped into the Rib. Nova Automotive checked it tested it preassurized it etc etc.... Only had to by piston, pin, clips and gaskets. Put it back in ( amazing how well the main halyard works as a hoist at the mooring) and it fired right up and sounds great. It should after working on injectors, injection pump etc etc.. My i sure do know that little 2GM now!! Oh well raced Sunday and will get a few more weeks out of summer yet. Greg
Top
#12341 - 09/12/11 08:29 PM Re: Will not start [Re: Groovin]
Class Co-President
Loc: Portsmouth, RI
Greg - I think you outdid me. I used the halyard and dropped the Yanmar onto a home built engine stand while on the hard. Dropping it into a Rib while floating seems like a more difficult task. Congrats and glad to hear of your success.
Bill Kneller
Rhapsody J/30 #348
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
1 registered (Rhapsody #348), 2 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Deck Square Footage?
by JeffSmithNJphoto
05/15/12 09:16 PM
Board Rules · Mark all read
