Re: Will not start
[Re: Groovin]
#12143
08/03/11 09:43 AM
08/03/11 09:43 AM
Posts: 83 Waukegan, IL
jhoskins
Waukegan, IL
Just had my HP fuel pump rebuilt. My engine was blowing a lot of soot and hard to start. Its like a new motor! Ive been told that the new deisel fuel is hard on old fuel systems and to add a fuel additive to every tank.
John Madcap 358
Re: Will not start
[Re: Groovin]
#12185
08/12/11 11:45 AM
08/12/11 11:45 AM
Posts: 41 New Orleans, LA USA
Toy Box
New Orleans, LA USA
There is no doubt you have air sucking somewhere, I recently had the same problem. I started with have the injectors re calibrated, then started at the fuel pump on the starboard side, one was tight, but just not tight enough. Then I moved to the injectors and bled them there. That was the problem. It can be quite frustrating, I know. Toy Box
Toy Box
44
guests, and 14
