beppe
Loc: Bethesda, MD
does anyone know the dimension of the boom track of the J30 ? The clew slug on my main keeps coming out of the boom with strong winds, and i need to fix the boom and was thinking of replacing the slug with a car instead. thanks.
Rhapsody #348
Class Co-President
Loc: Portsmouth, RI
Many of us have this problem. I now use a reinforced velcro loop around the boom and have also seen people use a sail tie looped around the boom or a spectra loop. It runs through the clew cringle and around the boom. You don't need a slug this way.
Cap'n Vic
Loc: Newport and Naples
roger, roger ... velcro loop 3x or so also getting common on boats way larger than the J30. and it slides better than those slugs. new velcro each season is nice.
NaturalHigh
My Velcro loop on my brand new sail is starting to pop loose in the heavier stuff. I am not impressed. My slug blew out two years ago. Made quite the bang!
Rhapsody #348
Class Co-President
Loc: Portsmouth, RI
the velcro loop on Rhapsody is 2.5 turns around the boom. Never had a problem with it separating. The boom circumference is 12 inches so the velcro should be about 30 to 33 inches long.
NaturalHigh
Buggers put too short of a strap on. It only goes 1.5 times around (basically once through the clew).
No convenient sailmakers to get another sold on, but really I can just tie on an additional strop with webbing like I do on my other sail.
The end of the boom is tapered on the end. At full outhaul, how do you keep the strap from sliding up there and getting loose and then hung up there when trying to ease the outhaul?
Rhapsody #348
Class Co-President
Loc: Portsmouth, RI
Do it the easy way and just wrap a sail tie around a couple times through the cringle, then tie it off. It should be tight enough so it you can't slide the aft end of the sail off the boom if the tack is pinned where it should be. There is no problem adjusting the outhaul the way you would normally. I actually found it was easier to adjust because the slug would sometimes bind in the boom track when under pressure.
Cap'n Vic
easiest way to use velcro strap is to curl the velcro loop through the ss ring in a quick building loop, then attach the shackle. two min max ... this is about 5 ft of double sided velcro. It is not snugged really tight and slides nice.
NaturalHigh
Confirmed the other night while sailing, when I am at full outhaul, the cringle is past where my taper begins. there is no way to keep the strop from sliding back onto the taper. Veddy inerestink.
Oh, and my velcro is definitely too short. Buggers.
