Most Online238Feb 9th, 2024
J/30 Class Approved Replacement Winches
#9239
04/06/10 11:11 AM
04/06/10 11:11 AM
Posts: 186Barrington, RI
cstoddard
Barrington, RI
J/30 Class Rules paragraph 5.4.1.5 has an "Official Interpretation" annotation that states;
A list of approved replacement winches is available from the Class Measurer.
The list of approved replacement winches will be maintained on the One Design Class Rules forum and updated as necessary.
Table of Approved Winches for the J30 as of 22 August 2011
Winch
Power Ratio
Weight (lbs.)
Primaries - 2 speed
Barient 25 (Original)
44:1 and 14:1
11.9
Lewmar 43)
43:1 and 15.6:1
12.5
Lewmar 44
44:8 and 13.9:1
12.6
Lewmar 44ST
44:8 and 13.9:1
12.6
Lewmar 44STOR
44:8 and 13.9:1
10.9
Lewmar 40ST
40:2 and 13.2:1
10.7
Harken 40 or 44ST
39.9:1 and 13.5:1
11.9
Harken 46 or 46ST
46:5 and 11.7:1
17.2
Harken 42.2
42:1 and 14.2:1
13.6
Harken 44.2ST
44:1 and 13.8:1
Secondary - 2 speed
Barient 21 (Original)
30:1 and 7.1
9.3
Lewmar 30
30:1 and 7:1
6.4
Harken 32.2
32:1 and 6.8:1
7.3
Halyard - 1 speed
Barient 10 (Original)
7.6:1
3.7
Lewmar 8
7.9:1
3.09
Harken B8
7.5:1
2.31
The table is available to download and print via the attached Word document.
Charlie Stoddard Falcon #229
Re: Winches
[Re: LChristy ]
#12217
08/22/11 02:01 PM
08/22/11 02:01 PM
cstoddard
Barrington, RI
The Lewmar 40ST has been added to the approved list for primary winches
Re: Winches
[Re: sonskyn ]
#12722
12/13/11 07:50 AM
12/13/11 07:50 AM
cstoddard
Barrington, RI
with all the new models that have been introduced I will update the list The evo 45 will probably fall in with it
Re: Winches
[Re: sonskyn ]
#12738
12/17/11 12:11 PM
12/17/11 12:11 PM
Posts: 179Apponaug Rhode Island
sonskyn
the Lewmar 40ST would be a replacement for the secondary and not the primary winches, if considering Lewmar: the hole pattern for the Lewmar EVO 45ST does not match the Barient25; the "Fast Fit" idea was never implemented, no studs supplied. Winches are mounted in the conventional manner.
Re: Winches
[Re: sonskyn ]
#12741
12/18/11 05:41 PM
12/18/11 05:41 PM
cstoddard
Barrington, RI
The 40's are not approved for use as a secondary they are two large Power ratio's are to high
Re: Winches
[Re: NaturalHigh ]
#13627
06/15/12 09:03 AM
06/15/12 09:03 AM
cstoddard
Barrington, RI
I see no reason why we Anderson's can't be approved and added to the list as long as they are in the same power ratio area as the Lemars and Harkins let me know which one you are looking at and I will review I did put a new pair of the Harkin 40.25 Self tailers on this year and the crew love them tons of power
47
guests, and 14
spiders.
Admin ,
Global Mod ,
