Re: 2gm losing prime
[Re: bananas]
#12291
08/30/11 05:44 PM
08/30/11 05:44 PM
Posts: 9 Hammond La.
kbuhler
Gulf Coast District Governor
Hammond La.
Yes, I have this past summer. The bleed screw was the problem. About 50 bucks took care of it. After 30+ years it just were out. I replaced the bowl and the washers Jalapeno30
[Re: bananas]
#12292
08/30/11 06:30 PM
08/30/11 06:30 PM
Posts: 147 Vancouver, BC, Canada
Vampire
Did you service the filter? Many times the o ring on the filter housing can get pinched or people over tighten the threaded ring and crack it.
Each of these allow an air bleed.
Vampire #18 Don Bite Me
51
guests, and 0
