#12416 - 09/30/1108:22 PMDrill holes in the Bilge for Winter
Cap'n Vic
Loc: Newport and Naples
So Ok Mid Sept. I'm out of the water in NPT. and getting 526 ready for winter. This year I decided to drill a 1/4 inch hole in the bottom of the bilge to handle any water coming down the mast ... the boat will be shrinkwrapped, but uninspected for 6 months. I'm still pissed off from a few years ago when after i had varnished the floor, water came in and screwed that job up. Basically used a 10 in. 1/4 in. drill bit at a sharp angle from inside, and it turns out I did drill a bit through the lead.
I will redrill the hole with a 3/8 bit in June and use my favorite gray marine tex to fill it ... then if that works a year from now I will drill out the 1/4 in. as close to the same spot as I did this year with the same drill bit at the same hard angle. Also noticed puddle at bottom of mast so drilled another drain hole there.
Attachments VeeJayhole1.jpg[59.59 KBytes] - (293 downloads) Description: Drill bit angle actually touches opposite side of bilge
VeeJayhole2.jpg[25.33 KBytes] - (290 downloads) Description: hole comes out an inch or so down lead keel
VeeJayhole3.jpg[34.36 KBytes] - (290 downloads) Description: Hole at bottom of mast at sharpe angle. fortunately the boat is tilted slightly to port.
#12464 - 10/08/1111:40 AMRe: Drill holes in the Bilge for Winter
[Re: Cap'n Vic]
whitedolphin
Loc: Atlanta, GA, USA
Haha! As a southern sailor who doesn't have these kinds of problems, this is the craziest thing I've ever heard.
I had to shows this to a few folks: "check it out - these guys are drilling holes in their boats!"
I guess you gotta do what you gotta do!
On a side note Vic, we've just added the Porsche of Naples Cup to our winter "little boat" sailing plans - don't have all the details yet, but if our schedules work out, I'd love to come crew for you while we are down there - never actually sailed another J/30.
#12465 - 10/08/1105:52 PMRe: Drill holes in the Bilge for Winter
[Re: whitedolphin]
Cap'n Vic
Hey ... one more patch won't mean a thing. J30 sailors are supposed to be nonchalant about anything less than the keel falling off. (( I don't think anyone has seen that documented ))
I will see how this drain works in Jan. when I visit ... I expect to see an icicle all the way to the ground.
Always entertaining for us to show off our nonchalant racing of a cruising rigged J30.
Have a 19 mile run to Marco scheduled tomorrow. ~10mile spin if the wind holds NE, weather mid 80s, kind of flat, hopefully sunny if this front finishes tonight.
moving the boom photo below ... don't leave it on during the summer ... while it sits in it's slip.
Attachments IMG_3345e.jpg[57.88 KBytes] - (184 downloads) Description: J30 mast transported in ford focus.
#12546 - 10/25/1111:25 AMRe: Drill holes in the Bilge for Winter
[Re: Cap'n Vic]
Conundrum
Loc: Oxford, MI
OKAY, so the idea of drilling holes is distasteful. But, How do you guys deal with the puddling at the bottom of the mast. I have just replaced the wooden floor there and am very concerned about the water that accumulates there too. The little hole to the bilge is not that far fetched. Other ideas?
#12547 - 10/25/1111:34 AMRe: Drill holes in the Bilge for Winter
[Re: Cap'n Vic]
whitedolphin
I put a very small 120V fan down by the head, pointing in the direction of the mast base and the transducer access hatch (which I leave open). Figure that the water will come in, but it will dry very quickly.
I also run a AC (summer) and a Dehu (winter) full time, so it stays pretty dry in there.
#12550 - 10/25/1103:04 PMRe: Drill holes in the Bilge for Winter
[Re: Cap'n Vic]
Conundrum
Loc: Oxford, MI
The Teak and Maple (originally Holly) at the base of the mast I have done myself. Purcased the wood at the Woodcraft store. I glued (epoxied) the Maple to the Teak first then epoxied each in place and screwed each to hold. I will plug, sand and finish with 6 coats of Goldspar satin. the main cabin was done this Summer. I love the look. So does wife.
#12552 - 10/25/1106:33 PMRe: Drill holes in the Bilge for Winter
[Re: Cap'n Vic]
Conundrum
Loc: Oxford, MI
I think the answer lies in how dry the wood can be kept. Holly is way more expensive than Maple. Both require you buy a significant piece. A good seal at the bottom and the surface will go far. I almost wish that i had completely coated all the surfaces with the epoxy resin. I did not. I only used it ti bond the pieces together. I sure would like to seal the mast better. The headstay sheave box is a big rain scoop. the drain is forward of the step and the mast water sits aft of the drain. Your little hole there looks inviting.
