Re: Cockpit Ballet
[Re: Russ Atkinson]
#12441
10/05/11 10:38 AM
10/05/11 10:38 AM
Cap'n Vic
Newport and Naples
1st only say "sorry" when there is blood on the deck. [that's a carry over from the J24]
Re: Cockpit Ballet
[Re: cjbuydos]
#12446
10/06/11 10:27 AM
10/06/11 10:27 AM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
We have the main trimmer release the jib sheet on a tack to minimize traffic. So on a tack they, cleat the leaward traveler line, release the main a bit, release the jib sheet, move to weather right aft of the primary winch, pull traveler to weather and trim main, put a few wraps on the winch with the windward jib sheet so we are ready to tack. If your main trimmer can handle this, it will really cut down on traffic.
Re: Cockpit Ballet
[Re: cjbuydos]
#12449
10/06/11 03:51 PM
10/06/11 03:51 PM
Posts: 678 Maryland, USA
Bob Rutsch
Maryland, USA
You might look with these on J30.org and elsewhere: J/30 Crew Assignments Rhapsody Crew Guide (Excel File) UK-Halsey J30 Crew Guide (PDF)If it's tacking the Genoa you are interested in, here's our approach. Light weight crew or mainsail trimmer drops down to leeward to release jib. Jib trimmer gets in position over other primary winch with 2-3 wraps. Skipper counts down tack. Release old sheet when luff breaks making sure all wraps are free of the winch. Tail the new sheet getting as much as possible early. In light air grind the last few inches using the winch. In med-heavy air, hand tail off to other trimmer then grind.
Re: Cockpit Ballet
[Re: Bob Rutsch]
#12456
10/07/11 08:42 AM
10/07/11 08:42 AM
Cap'n Vic
Newport and Naples
see Moves for a hint. when rotating crews are the norm ... insist they do it the same way everytime. left handed people always on port. generally one of the two trimmers has done it before and will be able to train the other. four hands on the working sheet working as fast as they can to zonk it in. which depending on age ... can be Horrendusly slow ... duh... goal is a 10 second tack without need for skirting. most trimmers don't understand how fast it is required to get the sheet in ... to be minimally j30 competitive. we've been known to do tacking drill in the NPT mooring field. nothing like putting pressure on guys to get them to speed up. the 163 is a tiger with a long tail.
35
guests, and 1
spider. |
