I'm in the process of rerigging my boat. Presently, my spin topping lift and downhaul are led back to the cockpit on the starboard side of the cabin top where they terminate in Harken cam cleats. The topper can also be cleated at the deck exit plate on the mast. Has anyone moved their pole downhaul to a swiveling cam cleat arrangement and placed it near the base of the mast? That would allow my foredeck men to adjust the pole themselves instead of calling back to my pit man.
Thoughts and suggestions would be appreciated.
Bob Rude Mmmmm #352
Re: Pole Downhaul
[Re: Bob Rude]
#12611 11/02/1108:40 PM11/02/1108:40 PM
I've mounted a pad just forward of the mast and installed a spring loaded stand-up block that has a cam cleat. This allows the mast / foredeck to control the downhaul. I also lead the line aft so it can be set the same way you do now. The connection to the spin pole bridle is made with a block on a shackle. Although the extra purchase isn't needed, it has the effect of keeping the block at the base of the mast held upright when you try and release the line from the cam cleat.
I have the setup stowed on the boat right now. Next time I'm at Rhapsody I'll take a picture so you can see.
If the twings are led forward of the shrouds, the pole downhaul is redundant. The twings provide enough downward force to keep the pole still. I do not use the down haul on a windward leeward course. Only if tight spinnaker reaches are the order of the day, do I bother to rig the downhaul.
Re: Pole Downhaul
[Re: sailon]
#12613 11/03/1111:16 AM11/03/1111:16 AM
when the wind is up, I've found twings alone are not enough. In lighter air, we don't rig the downhaul and use just the twings. I have replaced a bent ring on the mast track when the pole skied in heavy air without the downhaul.
To keep your pole from accidentally skying, make an easy-to-release knot on the downhaul line just before the line runs through a block or fairlead. Viola! No more skying! (Of course, you've got to find the right position to place the knot!) Duh!
POLE UP!!!!
Re: Pole Downhaul
[Re: Bob Rude]
#12615 11/03/1105:15 PM11/03/1105:15 PM
we stopped leading the pole lift back when we found "certain" pit crew had a tendency to release it accidentally when foredeck crew was working on the foredeck. not making foredeckers happy... some of those certain people were those who believe that you Have to loosen the pole lift to gybe. it must be a carry over from other boats.
Thereupon made rule only foredeck people will lift/drop pole... we added a nylon cleat a couple of feet off the deck on the starboard side of the mast to lock it. this was not a question of what is the best way ... but what way kept foredeckers from getting bopped.
downhaul still runs back old fashioned J30 way from padeye turning block in front of hatch. since we are launching/retrieving spin via hatch ... the pole run back to base of mast seems to add a bit of complexity when the hatch is open.
Yes, I am sure if the same foredeckers were on all the time, and we always made the mark with room to spare, downhaul to mast is OK, but we work on reducing complexity for the senior citizens rotating foredeck duty.
Pit and guy trimmer control the position of the pole from the cockpit.
roger, roger on that knot ... works for us ... I was able to use a clamp to straighten out the ring the one time we skyied hard ... now just keep a knot in ... which i will remember to retie tomorrow. thanks for the reminder.
Good ideas guys. Some re-rigging/pole work is on my winter list and this is a good add. When possible, pics would be great as I'm not quite visualizing the block placement/layout. Probably just not enough coffee yet this AM... - Jeff
- Jeff J/30 #426 - Watusi
Re: Pole Downhaul and Pole topping lift
[Re: JBro]
#12626 11/07/1108:22 PM11/07/1108:22 PM
So Ok ... We continue to get fewer and fewer "educated" spin people so "the program" has to be really tightened up.
When you are dealing with early teens and senior citizens ... you have to simplify on top of simplify. One of the rules we have is same thing same way everytime. we don't do a lot of upscale variations. And everyone is supposed to do things the same way. Then all the other crew has a hint as to what each other is doing. If something doesn't work ... we try to figure out how to make it simplier.
This month after seeing how my foredecker forgot some stuff over the summer, and my 13 year old crew kid was struggling to raise the pole by himself as we were short crew.
we are trying this program:
1. The pole is always first attached to mast before raising, and always dropped to the deck before detaching from mast. there is an arrow on the mast as to where the pole is supposed to be.
2. added block to base of mast ... just lashed on. this way someone raising pole has the topping lift in left hand and can push the pole up with right hand ... which allows a safer footing on the deck. instead of pulling down they are pulling up ... which is a more stable position with boat motion.
3. the downhaul is premarked ... so there will be no need to figure out how high to raise the pole ... you just raise it till it stops. I hate it when they ask is the pole high enough.
Will see how this works out during November. Our goal is the 8 second pole rise ... everytime. Don't laugh ... you have to have a goal.
Vic - another foolproof way that J/World teaches for J/24s, also works for J/30...
1. Set the spin pole ring on the mast at the height you want before getting underway 2. Clip pole lift to the ring with the trip line on the shackle facing out so you can grab it. Lock the pole lift shackle in position with just a little bit of slack (eg 1"). 3. Rig outboard end of spin pole jaws up with the guy already through the jaws. 4. Clip inboard end of pole to wherever you stow it while underway (e.g. base of shroud) 5. When ready to set, make sure there is some slack in the guy 6. Foredeck unclips inboard end of pole, and slides aft in between mast and shrouds. 7. With jaws up, pick up the pole using the bridle that pole lift gets clipped to 8. Hold the ring on the bridle against the ring on the mast with one hand, use other hand to unclip pole lift shackle, then reclip shackle to bridle ring. 9. Push pole forward with outboard end on proper side of headstay. 10 Attach inboard end of pole to ring on mast track. The pole is magically at the correct height, with nobody having to adjust anything.
assumes that the guy is in the forward jaw, both bridles are attached and the pole hanging on the base of the shroud with the working side of the topping lift also in that jaw all at deck level. this keeps the topping lift out of the way when tacking.
the program will be to detach at the shroud, toss the working side of the topping lift to the port side of the boat, attach the aft end of the pole to the ring, push the forward end of the pole around the furling drum, grab bitter end of topping lift at mast, and raise. Your option would eliminate the concern of tangling with the furling drum ... but in 4 ft waves it seems to require a bit of balance I cannot guarantee that person will have.
