• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » One Design Class Rules » Mast Step Postion
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97873
Northwest one-design 55185
Other J/30 Sailboats For Sale 29385
Comment Here - Draft Potential Rule Changes for 2009 28767
2010 Class Registration & Dues 28128
Rhapsody Transom Re-core and Other Areas Too 27235
J30.org Web Page 20716
2009 J/30 North Americans at Cedar Point YC 19505
J/30 Midwinter and Mardi Gras Regatta 14944
Southern Straits 13271
Forum Stats
595 Members
27 Forums
2618 Topics
Page 4 of 4 < 1 2 3 4
Topic Options
#12860 - 01/12/12 01:29 PM Re: Mast Step Postion measuring [Re: Conundrum]
Cap'n Vic Offline
Loc: Newport and Naples
Don ... it appears that geometrically unless we are at 25 mm setback and solid back at partners ... we will be unable to reach target headstay length ... and have anywhere near enough tension to hold up a RF to work well. You should be just able to do it, considering that -1/8 in. probably is good to kick up forestay tension for a heavier foil. There is only so much tension we can use to pull the mast back with the uppers ... I don't like going over 35s.
Tomorrow we will be resetting #505's forestay as I just didn't realize how critical that mast step measurement is in limiting the adjustablity of the forestay.
I will measure what the forestay with a RF >>>HAS TO BE to look right for a 40mm setback and post.
We are in middle of season here and I am not up to pulling mast to reset this year.
Photo of mast full aft in partners:
[we use cedar shingles wrapped with shrink tape to lock mast position.
Same, same close to 11'6" locked back trying to measure over deck stuff.]
eP1110045.jpg [16.71 KBytes] - (208 downloads)
Description: J30 recommended mast position at partners
_________________________
Naples
J24 Bang!
NPT
Top
#12867 - 01/13/12 04:45 PM Re: Mast Step Postion measuring [Re: Cap'n Vic]
Cap'n Vic Offline
OK ... after several hours of readjusting with the help of Brian, J30 #22, we are running 35' 7+" forestay with the mast base set back at 40 mm, which we are not going to be able to change until the next time we pull the mast. At which point we will move it to the Min at 25mm. With no backstay on we are looking initially at a pretty straight mast with very little pre bend, basically to see how much bend we can generate with heavy backstay over 15 kts.
We will be working with this setup this weekend on the water, but unfortunately will not be able to tune up against another boat until the regatta the end of the month.
for the purposes of discussion I can't see how we can consider setting the mast step as "tuning" of the rig, but instead consider it bringing the mast into the necessary configuration for racing or maximum accepted performance.
1. If you ask a sail maker to build a J30 #1 they automatically assume headstay is 35' 10.5" because that is what the max head stay is supposed to be, and that gives the biggest sail. So by ordering a standard J30 #1 or even a 155 they expect you to be set up Max. If you are moving sails from one boat to another ... this needs to be the same.
2. to achieve that forestay length the mast step needs to be at 25mm ... there is only so much you can do to bend the mast where it don't want to be bent. So that has to be set at Min. to move the mast at the fractional back enough to get OK tension on the forestay at the target forestay length.
Naples
J24 Bang!
NPT
Top
#13221 - 03/12/12 10:01 AM Re: Mast Step Postion [Re: Russ Atkinson]
Russ Atkinson Offline
Loc: Rockwood, MI, USA
Back in January I solicited guidance on how to get the screws loosened on my mast step.
I'm pleased to report that after a winter of soaking the screws in WD-40, and with the combination of an impact driver, a 5 lb sledge, a propane torch and a 2 x 4, the screws loosened sufficient for me to beat on the step with the 2x4 and move the mast step back the required 1/8". The step is now OD compliant!
Thanks to all for your suggestions
Top
#13237 - 03/14/12 04:53 PM Re: Mast Step Postion [Re: Russ Atkinson]
NaturalHigh Offline
I tried getting mine loose yesterday with an impact driver with no success. I am 1" too far aft, although the boat seems to go like stink upwind still.
Will beat on it again tonight.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  cstoddard
Print Topic
View profile
Send a PM
View homepage
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
1 registered (Bob Rutsch), 7 Guests and 4 Spiders online.
X48 vs J30
Running the spin halyard
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Deck Square Footage?
by JeffSmithNJphoto
05/15/12 09:16 PM
Board Rules · Mark all read
