• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Window Replacement
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97873
Northwest one-design 55185
Other J/30 Sailboats For Sale 29385
Comment Here - Draft Potential Rule Changes for 2009 28767
2010 Class Registration & Dues 28128
Rhapsody Transom Re-core and Other Areas Too 27235
J30.org Web Page 20716
2009 J/30 North Americans at Cedar Point YC 19505
J/30 Midwinter and Mardi Gras Regatta 14944
Southern Straits 13271
Forum Stats
595 Members
27 Forums
2618 Topics
Page 4 of 5 < 1 2 3 4 5 >
Topic Options
#12813 - 01/06/12 03:51 PM Re: Using Polycarbonate for window [Re: Cap'n Vic]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Vic
I replaced mine when I got Falcon in 96 used lifecaulk to bed them no problem for until last year Falcon may live up the Bay but she goes off shore to Off Soundings every year and as been out it some very heavy weather
The boat is in the shed having the decks awlgripped so the windows are out
The Plex is dead and I will go with the auto safety glass
The other option that is out there which Cory Butlin did to Blitz is to install the Lewmar opening port windows which might be real nice down south I don't cruise Falcon that much so I'll spend the money on new Self tailers this winter
_________________________
Charlie Stoddard
Falcon #229
Top
#12818 - 01/06/12 04:16 PM Re: Window Replacement [Re: Hullabaloo]
whitedolphin Offline
Loc: Atlanta, GA, USA
Just to confuse you more, I redid mine with tinted Lexan MR10 sheet, which I bought off of ebay for next to nothing, then cut out with a table saw then a jigsaw for the curves.
MR10 is a special coated version designed for exposure to UV and abbrasion, and its nearly bullet proof. Its also really light. I did that coming up on 4 years ago and they are still crystal clear and not scratched:
Lexan* MR10 sheets improved Margard® II coating resists abrasion and defies graffiti to ensure a “like-new” appearance for many years to come. The next generation of UV absorbers, Margard® coating now incorporates enhanced UV absorbers to protect the sheet from the debilitating effects of sunlight. As a result, Lexan* MR10 is accompanied by extended warranties that are your assurance of long term product performance; 10 yr. prorated replacement warranty against breakage, yellowing, abrasion, loss of light transmission and coating delamination.^ 15 year warranty against yellowing and light transmission for qualified dual glazed systems.** Virtually unbreakable. High light transmission common to all Lexan* sheet products. Easily maintained without marring, hazing, or yellowing. Compiles with major model building codes
Top
#12855 - 01/11/12 04:14 PM Cleaning window frame and fitting Polycarbonate [Re: Cap'n Vic]
Cap'n Vic Offline
Loc: Newport and Naples
So OK ... to really clean the window frame it takes about 45 min apiece ... cutting off whatever was originally used, getting all traces of it off if you are going to use a high tech adhesive such as SikaFlex 295UV.
here is part 2 of the #505 window replacement series.
Naples
J24 Bang!
NPT
Top
#12856 - 01/11/12 04:28 PM Re: Cleaning window frame and fitting Polycarbonate [Re: Hullabaloo]
My previous owner used 5200. For me, it was more like 2.5 hours per port. I did all this over about 4 trips to the coast. Would love to find the guy who applied that stuff and beat him with a fresh tube of 5200.
I used simple white silicon to replace - it collects dirt a bit on the outside, but is very easy to clean with your thumb and will be very easy for the next guy.
Top
#12857 - 01/11/12 04:40 PM Re: Cleaning window frame and fitting Polycarbonate [Re: whitedolphin]
Cap'n Vic Offline
Dremel with rough drum. and stay away from the outside deck edge ... Taylor did not break through the gel coat except for some "voids" that we see everywhere on original j30 gel coat.
Agree 5200 is dumb as many people think it is the "all" around adhesive. The four windows took 1 tube of Sikaflex 295 UV which is recommended for polycarbonate. more on that lata.
Naples
J24 Bang!
NPT
Top
#12858 - 01/11/12 05:25 PM Re: Cleaning window frame and fitting Polycarbonate [Re: Hullabaloo]
Russ Atkinson Offline
Loc: Rockwood, MI, USA
The last time I re-seated my cabin windows was 7-10 years ago.
I thought I would be smart and used black caulk thinking it would make the windows look bigger - insert prettier here - from a distance. Given that I never see the boat from more than 20 feet away, the windows don't look any bigger.
What I did gain was a mess. The black oxidizes and the crew's feet, rain, etc, drags black markes all over the cabin sides. Of course, I was also dumb enough to use it on the inside too, ugh.
It's on my list of things to do - somewhere below installing spartite around my mast.
One additional note: I've used 3M white polishing compound followed by paste wax on the windows. They clean up real nice.
Top
#12880 - 01/17/12 07:02 AM Re: Cleaning window frame and fitting Polycarbonate [Re: Russ Atkinson]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
just ordered safety glass windows yesterday $28.00 each not bad
Charlie Stoddard
Falcon #229
Top
#12944 - 01/25/12 10:42 AM Re: Cleaning window frame and fitting Polycarbonate [Re: cstoddard]
Cap'n Vic Offline
So OK ... final installment on bedding Windows.
follow up note ... already have one noticeable scratch ... was impact from jaw of spin pole ... don't ask ... but I wonder how well glass would have taken knock with jaw. But then don't they have those epoxy kits to repair dings from gravel to windshields?
Naples
J24 Bang!
NPT
Top
#12946 - 01/25/12 11:49 AM Re: Cleaning window frame and fitting Polycarbonate [Re: Hullabaloo]
Bob Rutsch Online   content
Loc: Maryland, USA
While I always enjoy watching Vic's videos, I'm most impressed by this young man Taylor. He always seems ready and willing to work, whether it's sailing or maintenance.
Top
#12974 - 01/28/12 08:49 PM Re: Cleaning window frame and fitting Polycarbonate [Re: Bob Rutsch]
Cap'n Vic Offline
if you keep in the context of 13 year old ... kid has very surprisingly competent moments ...
Today's racing proved to him that he can only trust his senior team mates [if they haven't been on the boat recently] to remember to do the right thing only "most" of the time.
I may have to have him start reviewing stuff with the old guys before we race. I'm thinking this is going to be hard for the old guys to have a 13 year old refresh their memories.
Naples
J24 Bang!
NPT
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
1 registered (Bob Rutsch), 7 Guests and 4 Spiders online.
X48 vs J30
Running the spin halyard
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Deck Square Footage?
by JeffSmithNJphoto
05/15/12 09:16 PM
Board Rules · Mark all read
