Alvaro,
I pulled the table out from my basement storage to take some pictures and measurements. Here is a
link to some basic dimensions. Let me know if there are any other dimensions you need. If you right click on any of the images, you can download the higher resolution photo.
This is a view of the table upside down, unfolded.
![[Linked Image]](http://j30.us/images/table/table-unfolded-bottom.jpg)
This is looking from the aft end on the bottom.
![[Linked Image]](http://j30.us/images/table/view-from-aft-bottom.jpg)
The center storage bins are shown, one with cover on, and the other with cover off.
![[Linked Image]](http://j30.us/images/table/center-storage-bins.jpg)
This is the hinge attachment for each table leaf
![[Linked Image]](http://j30.us/images/table/hinge-attachment.jpg)
This is a picture on where the table leg pipe is inserted.
![[Linked Image]](http://j30.us/images/table/pipe-insert.jpg)
This is a picture of a steel leaf support. The table legs are drilled so the steel supports can be inserted between the legs and rotate up to fit in block of wood mounted on the underside of the leaf to hold it up. .
![[Linked Image]](http://j30.us/images/table/steel-leaf-support.jpg)
