• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Deck refurbishment project
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97873
Northwest one-design 55185
Other J/30 Sailboats For Sale 29385
Comment Here - Draft Potential Rule Changes for 2009 28767
2010 Class Registration & Dues 28128
Rhapsody Transom Re-core and Other Areas Too 27235
J30.org Web Page 20716
2009 J/30 North Americans at Cedar Point YC 19505
J/30 Midwinter and Mardi Gras Regatta 14944
Southern Straits 13271
Forum Stats
595 Members
27 Forums
2618 Topics
Page 1 of 3 1 2 3 >
Topic Options
#12850 - 01/10/12 01:15 PM Deck refurbishment project
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
This fall I made the call to do a major deck refurbishment project. I'm looking at it as a "ship life extention project".
Falcons non skid was failing, the gel coat was not holding a shin, there was a collection of din's chips' etc. Although I had no major core issues on the deck I new that small areas need to be addressed. So I worked out a deal with the local yard I would strip the deck, overbore and back fill with epoxy all the bolt holes etc. They will handle the any glass work issues and the awlgrip paint job including spraying on new non skid. Afterward I will handle the re install of all the hardware.
At this date the boat is in the heated paint shed being worked on.
One issue that I found when stripping the boat is that the traveler bridge area (early hull) is only a single layer of glass it was starting to fracture. The fix is to fill in and overglass the entire traveler pit. A new Harken high track will be mounted for the windward sheeting car.
All the exterior teak has been removed and I am refinishing or remaking pieces as required ( having a full wood working shop helps)
I've got a friend who has a metal polishing and electropolishing shop so all the stainless fittings will be cleaned up.
pictures to be posted shortly
_________________________
Charlie Stoddard
Falcon #229
Top
#12877 - 01/16/12 09:55 AM Re: Deck refurbishment project [Re: cstoddard]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Here is a link to a great material to use for bedding hardware
http://www.pbase.com/mainecruising/rebedding_hardware&page=1
Charlie Stoddard
Falcon #229
Top
#12882 - 01/17/12 07:58 AM Re: Deck refurbishment project [Re: cstoddard]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Pictures of work in process.
Couple of shots of the work on Falcon’s Deck
  • Traveler pit has been filled in
  • On the foredeck shot the dorade fitting is filled in and you can see were they put the plywood filler for the bow cleat ( and missed placing it properly)
  • The bad gel coat on the cabin sides has been dug out and filled
Current schedule looks like we will have the boat available for mounting hardware February 4th and 5th will advise early next week.
DSC00078.jpg [67.33 KBytes] - (432 downloads)
DSC00080.jpg [208.26 KBytes] - (430 downloads)
DSC00083.JPG [60.23 KBytes] - (432 downloads)
Charlie Stoddard
Falcon #229
Top
#12890 - 01/17/12 01:38 PM Re: Deck refurbishment project [Re: cstoddard]
Cap'n Vic Offline
Loc: Newport and Naples
as the kids say with wide open eyes ... "cool!" or is it "neat!" but perhaps "Wow!" works as well.
Naples
J24 Bang!
NPT
Top
#12904 - 01/19/12 04:46 PM Re: Deck refurbishment project [Re: Cap'n Vic]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
They have had two guys preping the deck most of this week for filler and lots of sanding. Primer goes on tomorrow Will get some shots over the weekend. The surface is as smooth now as a baby's butt.
Looking to a Feb 4th weekend of hardware install Let me tell you the heated shed is nice to work in
Charlie Stoddard
Falcon #229
Top
#12906 - 01/19/12 06:21 PM Re: Deck refurbishment project [Re: cstoddard]
Cap'n Vic Offline
roger, roger ... it would have helped if they knew how to spray gel coat 30 years ago ... pit holes as the surface wears away seem to take a lot of extra work. lots of air bubbles didn't help. The non skid on the new boats is agressive in comparison to the old non skid patterns. if in doubt go a touch more agressive than you think ... the crew rather be sure of their footing than worry about a skin scrape. I used interdeck plus heavy non skid powder on the foredeck ... that is really agressive, but that's where it needs it. I'm up here for a couple of days ... going down to see them ice skate at the "yachting center" to make sure of what I'm missing.
Naples
J24 Bang!
NPT
Top
#12914 - 01/20/12 04:31 PM Primer Sprayed [Re: Cap'n Vic]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Here is a shot of the primer sprayed.
DSC00092.JPG [49.85 KBytes] - (338 downloads)
Charlie Stoddard
Falcon #229
Top
#12915 - 01/20/12 04:42 PM Re: Primer Sprayed [Re: cstoddard]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Primer in the previous shot is the "working" primer They have to go back and chase the "pin holes" etc followed up with more sanding and the final coat of primer With luck the white goes on next week
Charlie Stoddard
Falcon #229
Top
#13068 - 02/20/12 08:32 AM Re: Primer Sprayed [Re: cstoddard]
cstoddard Offline
J/30 Class Measurer
Loc: Barrington, RI
Deck painting was finished last week This weekend was spent putting the hardware back on the Crew pitched in (thanks Guys!) so its almost done. pictures shortly
Charlie Stoddard
Falcon #229
Top
#13069 - 02/20/12 09:42 AM Re: Primer Sprayed [Re: cstoddard]
Cap'n Vic Offline
Originally Posted By: cstoddard
[*]On the foredeck shot the dorade fitting is filled in and you can see were they put the plywood filler for the bow cleat ( and missed placing it properly)
This photo I am interested in .... are you planning to put the dorade back in?
And did you find the bow cleat joint a problem?????? we count a lot on that.
Naples
J24 Bang!
NPT
Top
Page 1 of 3 1 2 3 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
1 registered (Bob Rutsch), 7 Guests and 4 Spiders online.
X48 vs J30
Running the spin halyard
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Deck Square Footage?
by JeffSmithNJphoto
05/15/12 09:16 PM
Board Rules · Mark all read
