Re: Official prop thread
[Re: dlabrosse]
#12897
01/18/12 12:31 AM
01/18/12 12:31 AM
Posts: 88 Belmont, MA
Georges
Belmont, MA
Dominique, By backward reliability, do you mean satisfactorily as well? I try to gauge if your new martec, in addition to reliability, makes the backward thrust significantly more efficient - even with our small 15hp YM?
It is still always stressfull for me to pull out of a slip with strong wind from the hip. I would love to have more thrust and less torque:-)
[Re: NaturalHigh]
#12911
01/20/12 04:40 AM
01/20/12 04:40 AM
dlabrosse
Georges,
I mean that I can actually get backwards. There was so much slop in my prop that I needed to get to at least mid range RPMs to get any thrust in reverse. Often the prop would not properly unfold either. I sent it to Martec for a rebuild but the metal was sufficiently pink that they could not guarantee the integrity of the prop if it was re-built. So I bought a new one. Immediately I noticed reduced vibration and real thrust at idle in reverse. Way easier to get out of my slip. Which I do entirely in reverse. Yes I am satisfied with the performance of the prop. Have not gotten into nearly as much trouble getting in and out of the slip since it was replaced.
[Re: NaturalHigh]
#12966
01/28/12 12:24 PM
01/28/12 12:24 PM
Posts: 203 Oxford, MI
Conundrum
Oxford, MI
I have been away but excited to weigh in on the Martec. I bought a brand new Martec 14x14x1 for Conundrum for 2011. I found the backing power and the braking to be lacking and wondered why. My Catalina 30 had the same prop and it was 15 years old and still had good backing ability as well as good braking power. Tha Cat has 4000# more to stop. I wonder why the J config is as it is. Is true for the rest of you, Poor backing and braking? I do go forward at 6.6 kt @ 2600rpm and Yanmar 13 2GM
Re: What's wrong with this picture?
[Re: NaturalHigh]
#13084
02/22/12 10:18 PM
02/22/12 10:18 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Absolutely send it back for refurb. As long as the hole for the pivot pin hasn't been over-bored too much with an over-sized pin used already. Martec will weld up and refinsh the surface per my previous post in this thread.
44
guests, and 14
