977,783 Dacron Main
163,165 Ananda's Refit
Substitute Skipper Rule #13150
03/05/12 02:26 PM
03/05/12 02:26 PM
Richmod, VA
Phil Offline OP
Phil  Offline OP
Richmod, VA
There are a number of races that I will not be able to sail this spring due to conflicts with my daughters' lacrosse schedule. Am I correct that I can designate a substitute skipper for those races, someone who is a part of my crew on a regular basis, who can sail the boat in those events and that the fee for naming a substitute skipper is $25?
Re: Substitute Skipper Rule [Re: Phil] #13152
03/05/12 04:03 PM
03/05/12 04:03 PM
Maryland, USA
Bob Rutsch Offline
Bob Rutsch  Offline
Maryland, USA
That's correct, the Chesapeake Fleet has a provision to allow you to designate up to two of your regular crew (but not sailing professionals) to act as a substitute skipper for when you are not able to be on board. They may helm the boat in up to seven J/30 one-design races per season. Use the membership form from the winter meeting and send it with a check to fleet captain Ron Anderson. It will be great to have your boat out racing even when you are on the sidelines or in the stands.
Re: Substitute Skipper Rule [Re: Phil] #13160
03/05/12 06:26 PM
03/05/12 06:26 PM
Richmod, VA
Phil Offline OP
Phil  Offline OP
Richmod, VA
Probably a skipper upgrade as well !
Moderated by  Bruce Irvin
0 registered members (), 42 guests, and 8 spiders.
