977,800 Dacron Main
163,171 Ananda's Refit
Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Rhapsody 2011-2012 Winter Work - Deck Recore [Re: David Erwin] #12666
11/21/11 01:52 PM
11/21/11 01:52 PM
Rhapsody #348 Offline OP
Dave - the dark area shown on top of the deck in the photo above is where the teak toe rail was through bolted to the deck, inside forward edge of the cockpit. The aft bolt was the water source - very obvious to see when you look at the hole in the deck, and the position of wet core under it.
If you go to the blog, you can expand the photos by clicking on them to really see what is happening.
Rhapsody 2011-2012 Winter Work - Windward Sheeting [Re: Rhapsody #348] #12677
11/30/11 10:27 PM
11/30/11 10:27 PM
I decided to upgrade to a windward sheeting car this winter. Check out the latest on the Rhapsody Blog.
Re: Rhapsody 2011-2012 Winter Work - Windward Sheeting [Re: Rhapsody #348] #12680
12/01/11 07:11 PM
12/01/11 07:11 PM
Montreal, Quebec, Canada
Taras Offline
Taras  Offline
Hi Bill,
Maybe you can help me source something. I have been looking and looking for the longs threaded bolts that are running through the wood handrails. I had one shear off and have yet to find a replacement / looked all summer
Thanks
Taras
Re: Rhapsody 2011-2012 Winter Work - Windward Sheeting [Re: Taras] #12681
12/01/11 07:23 PM
12/01/11 07:23 PM
I also need to pick some up for a replacement since one is broken. I plan on using threaded stainless rod. I think it is size #10 with 24 threads per inch but need to verify. Try Jamestown Distributors at this link.
Wooden Hand Rail Replacement bolts pins [Re: Rhapsody #348] #12682
12/01/11 09:09 PM
12/01/11 09:09 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
I don't think replacing them with same size threaded rod is the best plan ... I think dumping the wooden rails is the best plan.
Or as a compromise see if you can go up a size without compromising an old piece of wood.
I have done two boats with SS rails and feel way safer than relying on these rinky dink long bolts from 30 years ago ... if one broke ... i am pretty sure the rest are showing signs of pitting as the photo indicates.
for some reason I kept the four best ones removed from 505 four years ago ... they all are pitted. I didn't have a problem with the wood rails until I ended up with a 225+ plus crewman when he was trying to put a reef in off shore. and then subsequently the pins started to break on 526.
J30 handrail pins.jpg [43.72 KBytes] - (1922 downloads)
hand rail bolt pitting prior to failure
Re: Rhapsody Transom Re-core and Other Areas Too [Re: Rhapsody #348] #12683
12/01/11 10:09 PM
12/01/11 10:09 PM
Oxford, MI
Conundrum Offline
Conundrum  Offline
Oxford, MI
Taras, I have (8) eight of them, they are 5.5 in x .160 in Flathead slotted SS. I saved them when I rehabbed my deck on Conundrum. I changed to Stainless steel handrails with welded 1/4 x 20 studs. 24 in long, from West Marine. Not shown in catalog but available as a special order, Rail-O-24-M Oval rail, male, $29. This one has solid flared bases. supplier is (www.Div-n-Dog.com ). I feel they are far superior.
The 8 bolts are yours if you want them. You probably want 10. They are not all perfectly straight, but free to a good home. See pic. The goo is just 4200 sealant, they'll clean up.
let me know at ddking3070@sbcglobal.net
CIMG5170.JPG [229.06 KBytes] - (1710 downloads)
Re: Wooden Hand Rail Replacement bolts pins [Re: Cap'n Vic] #12684
12/02/11 08:19 AM
12/02/11 08:19 AM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
Duh ... the ones I have are 4.75 end to end?
perhaps they have used different height rails during production runs?
[also replaced rails with WM 2fts]
Re: Wooden Hand Rail Replacement bolts pins [Re: Cap'n Vic] #12686
12/02/11 01:40 PM
12/02/11 01:40 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
It appears that there is plenty of thread. Seems that a Sawsall and a vice would make easy work of having 5.5" screws = 4.75" Or... Hacksaw and some elbow grease
New Teak - Rhapsody 2011-2012 Winter Work - Deck Recore [Re: Rhapsody #348] #13162
03/05/12 08:16 PM
03/05/12 08:16 PM
Thanks to Charlie Stoddard, Rhapsody has a new set of teak handrails and cockpit toerails. A little swap we made for carpentry vs system integration services. I've sanded the custom made teak pieces that have already been trial fit to the boat. The picture shows the rails with 11 coats of Epifanes Wood Finish Gloss. Much easier to do this in my basement than on the boat.
New-Teak-Handrails.jpg [88.09 KBytes] - (2162 downloads)
Re: New Teak - Rhapsody 2011-2012 Winter Work - Deck Recore [Re: Rhapsody #348] #13164
03/05/12 09:36 PM
03/05/12 09:36 PM
St. Margarets Bay, Nova Scotia
Groovin Offline
Groovin  Offline
Always nice to have fresh wood Bill. One of these days!
0 registered members (), 47 guests, and 14 spiders.
