• Home
  • Class
    • Membership Renewal / Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
    • Diesel Engine Maintenance
    • J/30 Drawings and Files
    • J/30 Brochures & Journals
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2013 J/30
North Americans
July 25-28
Barrington YC
Barrington YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » mast foot
May
M Tu W Th F Sa Su
Vendredi, Walter, ericevanthomas, PJKelty, KenSciarappa
642 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
j30news
(Views)Popular Topics
Dacron Main 186224
Northwest one-design 122739
Rhapsody Transom Re-core and Other Areas Too 47762
Other J/30 Sailboats For Sale 47511
Comment Here - Draft Potential Rule Changes for 2009 42844
2010 Class Registration & Dues 36973
J30.org Web Page 27958
2009 J/30 North Americans at Cedar Point YC 27900
Southern Straits 20678
J/30 Midwinter and Mardi Gras Regatta 20546
Forum Stats
642 Members
27 Forums
2873 Topics
Max Online: 79 @ 11/14/12 01:22 AM
Topic Options
#13587 - 06/05/12 07:12 AM mast foot
nemonaute Offline
Loc: Québec City, Canada
Hi,
I'm a new J30 owner in Québec City, Canada. (sorry, I speak english very bad ! grin )
My question is about mast foot.
When we put the mast on, we notice that the hole for the mast on the deck is bigger than the mast circumference. What do you put to fill this gap and how do you weatherproof the mast foot ?
We put some little blocs, then wrap with tape, but it seems not very good to me. I would like to know how other J30 do it...
If you have some picture of your mast foot, it will be very helpful for us ! Thanks !
Marie
Top
#13588 - 06/05/12 08:12 AM Re: mast foot [Re: nemonaute]
Class Co-President
Loc: Portsmouth, RI
Marie,
There are typically wooden shims or a urethane compound such as "Spartite" poured to keep the mast in position. It is important to have the mast in the proper position. The position is best set with the shrouds and stays loose. The mast step should be located 1" back from the molded lip on the step in the vberth. The mast should be centered in column over the keel. A good trick is to use a sight line hanging from a step ladder about 60 feet behind the boat while on the hard so you can use it as a reference to see from the bottom of the keel to the top of the mast. I used lines tied around the mast and turning blocks to the winches to properly center the mast. The front of the mast should be positioned 11.5 feet from the stem of the bow, also using lines and a turning block to winches so the mast can be pulled forward. Note that the mast may not be centered in the hole when it is properly aligned to the keel.
Once the mast is centered and positioned fore/aft correctly, use wooden wedges to fix the mast position at the deck. An alternative is to create a mast collar using a urethane such as "Spartite". See my Rhapsody post that also contains a link to my blog where the Spartite process is described.
After the mast is positioned properly, you can put on a mast boot. There are some sold that are one piece and slide on the mast before the mast is inserted in the hole. Rigrite sells a mast boot on this page. Others have taped on rubber seals and used canvass or Sunbrella covers.
On Rhapsody I use Spartite and the Rigrite mast boot that was split in the aft seem and taped to allow easy removal. The Spartite helps keep the mast centered, and helps keep rain from dripping down the mast.
_________________________
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#13589 - 06/05/12 09:04 AM Re: mast foot [Re: nemonaute]
D. Bartley Offline
Loc: Chicago, Il. USA
On early J/30s, the hole for the mast in the deck is very large... much bigger than later models. They used wooden partners to position the mast, and reduce the leaking.
Later models have a plastic(?) mast boot around the mast that fits pretty snugly over the hole. If that is no longer on your mast, SparTite would be a reasonable substitute.
What is your hull number?
Dennis Bartley
Planxty, s/n 23994
hull 205
Top
#13590 - 06/05/12 10:02 AM Re: mast foot [Re: D. Bartley]
Class Co-President
Loc: Portsmouth, RI
Marie has "NEMO" hull 283
Bill Kneller
Rhapsody J/30 #348
Top
#13591 - 06/05/12 10:16 AM Re: mast foot [Re: Rhapsody #348]
nemonaute Offline
Hull number is 283.
I think it is one of the earlier models because the hole is very large.
The former owner give us some little blocs to put around the mast, in order to fill the gap. But it seems strange to me, because theses little hard blocs are making hard pressure at the contacts points. Moreover, the deck mast foot seems already stressed, there is little cracks. I think that the pressure from the blocks will worsen the cracks.
A picture is better than words :
Then we wrap it in a special mast foot tape in order to waterproof the mast foot, but it is not perfect, there is water leak while raining.
So, I am looking for a better system.
I will look at spartite and other mast boot. We want something that can be remove easily because we will probably dismast next fall to change pulleys in mast head (there are old pulley for cable halyard but the current halyard are ropes, not cable, so there is a lot of rubbing).
(Please correct me if I use bad words, because I am not familiar with english marine vocabulary !!)
Top
#13592 - 06/05/12 10:18 AM Mast Step and partners positioning [Re: nemonaute]
Cap'n Vic Offline
Loc: Newport and Naples
Also see thread beginning at
Mast Step Position
Naples Winter 12/13- #505
Newport Summer 2012 - #526
Naples Winter 2011/12 - #505
Top
#13593 - 06/05/12 02:21 PM Re: mast foot [Re: nemonaute]
Bob Rutsch Offline
Loc: Maryland, USA
That's the standard size hole not the big one. Mast boot tape will do the job. But jib sheets tend to break it down. So I taped it, than covered it with something like this: A practical mast boot. Instead of truck tire inner tube I used a piece of sunbrella fabric.
A 7 MB PDF version with a better view of the above on page 56 here.
Top
#13594 - 06/05/12 03:15 PM Re: mast foot [Re: nemonaute]
nemonaute Offline
Hello,
Thanks for answers !
About Spartite :
Do you pour the Spartite when the rigging is tighten or loose ?
I understand that you pour it when the rigging is loose. But isn't it better to pour it when it is loose ? Because the Spartite will solidify and then, when you will tighten the rigging, there will be compression on the Spartite collar ?
Can you easily dismast and restep the mast with this Spartite ?
Do the Spartite collar stay on the deck hole or stay on the mast when you dismast ?
Thanks !!
Top
#13595 - 06/05/12 06:29 PM Re: mast foot [Re: nemonaute]
Class Co-President
Loc: Portsmouth, RI
Here is the Spartite website link that contains a FAQ section. Spartite is poured with the rigging loose, but the rig positioned by lines tied around the mast and winched to make sure it is centered and proper fore-aft location. The backstay should be on tight when Spartite is poured.
You line the hole with Vaseline on the mast and deck so the Spartite "donut" will slide when you pull the mast. It usually stays with the mast.
Bill Kneller
Rhapsody J/30 #348
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Who's Online
0 registered (), 1 Guest and 1 Spider online.
Top Tick
End of Season ...
Opti direct up to J/30
Coming soon to water near you!
Sometimes it just a fade day
Toe Rail
by dennejo
05/24/13 11:45 PM
balsa core thickness
by dennejo
05/24/13 11:35 PM
Cost of New Dacron Main
by Bob Rude
05/24/13 12:20 PM
1982 J/30 - Hull #392 'Salsa Verde' - Sarasota, FL
by martin
05/22/13 02:15 PM
2013 J/30 North Americans 25 - 28 July @ Barrington YC
by Rhapsody #348
05/21/13 02:53 PM
Original cabin table dimensions
by Cap'n Vic
05/21/13 10:13 AM
Cabintop opening for Mast
by AndyR
05/20/13 07:50 PM
Insurance
by sonskyn
05/20/13 07:12 AM
LPG of 163% Genoa?
by JeffSmithNJphoto
05/16/13 08:00 AM
head sink
by JeffSmithNJphoto
05/14/13 06:17 AM
Board Rules · Mark all read
