Idle/Kill Switch Issue
#13615
06/13/12 12:43 PM
06/13/12 12:43 PM
Posts: 18 CHICAGO
JKC
CHICAGO
Good morning, I'm trying to adjust idle on the old 2GM and am running into an issue: I can get it to idle nicely around 1250 rpm. It dies around 1000. While adjusting the idle is simple, when I get it in a good running position, the kill switch physically doesn't have enough room to move to kill engine. Am I missing something, or is there better idle adjustment system/hardware out there to get this done? If you look at picture, kill knob pulls the cable on top, compressing spring all the way etc. trying to move lever back, but no matter how much adjustment is done, the hardware fitting doesn't enough room to release lever far enough to kill the engine. Any ideas? Thanks John Circus 60219
Re: Idle/Kill Switch Issue
[Re: JKC]
#13623
06/14/12 11:40 AM
06/14/12 11:40 AM
Posts: 2,668 Portsmouth, RI
Rhapsody #348
I fixed the link for your picture in the original post with the new link you sent. Look at the Yanmar 2GM Operations manual page 12 and 16 at this link. First - there is a separate cable used for fuel cutoff to stop the engine. The engine should not stop using the throttle control. Next - if you are unable to reduce the idle using the adjustment, you may have an injector problem (e.g. injector nozzle plugged so it runs very rough and dies). You may want to pull the injectors and take the injectors to Torrenson marine (since you are in Chicago) to be pop tested, nozzles replace and shimmed. Once they are replaced, you should have an easier time adjusting the idle. It will probably run you ~ $100 if you take them to them. Make sure you ask them for a set of new insulators to replace when you put them back in the engine.
guests, and 1
spider. |
