Hello,
I am still thinking of this...
I would like a mast base plate, where I can put a lot of blocks.
Like this : http://www.pridemarine.com/index.cfm?category=10007|10863|10864&product=10978804&code=Garhauer%20MS%2D4
On RigRite website, I found this :
Low Profile Deck Collar Assembly for 4060: K-10858:
Low-profile 4060 Deck Collar Assembly, for keel stepped masts. Deck Collar Rings are bolted together (with Deck in between), using (8) 5/16" bolts and nuts. Mast Support Tabs bolt through Collar Rings, 3/8" bolt is later installed through Mast and Support Tabs preventing the deck from rising under rigging loads. Base size is (maximum) 8 3/4" long x 6 3/4" wide x 3/4" high. Kit includes (2) K-10923 Low-profile 4060 Deck Collar Rings, (2) K-10931 Mast Support Tabs, (1) 3/8" x 5" bolt with locknut, and the K-77509-18.5 rubber Mast Wedge. Original Assemblies used the K-10694 Urethane Mast Collar (no longer available), as shown, which mounted between deck and upper Deck Collar Ring, requiring removal of Deck Collar Rings when unstepping the mast.
http://www.rigrite.com/spars/kenyon_spars/4060-MORC.html)
Do you think that it is possible to put blocks on this RigRite part ?
Or maybe put a mast base plate (like this one of pridemarine) on the RigRite part ?
Does anyone know the price of this rigrite part ? I can't find it anywhere and I can't ever find an email adress to ask them !??
Thanks !
Marie
