Cradle/Pad combination for trailer?
[Re: Rhapsody #348]
#14079
10/09/12 12:59 PM
10/09/12 12:59 PM
Cap'n Vic
Newport and Naples
Always good to see photos for ideas ... Recent photo here at J30.us shows Crusader's trailer in New Orleans for the NA. Looks like it uses doubled 3/4 plywood shaped as done on a cradle, and bolted onto steel supports, instead of the typical adjustable screw pad arangement. For a long haul I like that support.
44
guests, and 14
