978,284 Dacron Main
163,310 Ananda's Refit
Removing keel for trailering? #14125
10/22/12 09:18 AM
10/22/12 09:18 AM
Atlantic Highlands, NJ
JeffSmithNJphoto Offline OP
Someone mentioned that it is possible to remove the keel and lie the boat at an angle on the trailer to meet width and height restrictions. I'd appreciate any suggestions and information, especially regarding cost.
Re: Removing keel for trailering? [Re: JeffSmithNJphoto] #14126
10/22/12 02:26 PM
10/22/12 02:26 PM
Milwaukee, WI
arcpix Offline
arcpix  Offline
Milwaukee, WI
I am pretty sure that this will not get you around the width restrictions and for height, the boat on a trailer should be fine on all interstates. We just moved ours from MN to WI on I-90 and I-94. Had to get a wide load permit for both states (through an expeditor it was just under $100 - included both states). On the trailer, the boat with the rig on top, was 13' so no problems on the highway for a 300 mile drive.
Re: Removing keel for trailering? [Re: JeffSmithNJphoto] #14131
10/24/12 08:33 AM
10/24/12 08:33 AM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
We just trailered the boat from Mi. to La. and back. Pulled permits in all states for the width; boat was 12'11" high.
No problems.
Trailered it from Mi. to Key West and back several years ago. Had it hauled from New England to California and from Cal to Mi. Never once even thought about pulling the keel
Re: Removing keel for trailering? [Re: Russ Atkinson] #14137
10/26/12 07:22 AM
10/26/12 07:22 AM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
so ok ... maybe on a Melges 32 ... but not on a j30.
eIMG_0009.jpg [70.75 KBytes] - (1201 downloads)
removing keel to do this?
0 registered members (), 41 guests, and 14 spiders.
