• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Windward sheeting cars
May
M Tu W Th F Sa Su
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97873
Northwest one-design 55185
Other J/30 Sailboats For Sale 29385
Comment Here - Draft Potential Rule Changes for 2009 28767
2010 Class Registration & Dues 28128
Rhapsody Transom Re-core and Other Areas Too 27235
J30.org Web Page 20716
2009 J/30 North Americans at Cedar Point YC 19505
J/30 Midwinter and Mardi Gras Regatta 14944
Southern Straits 13271
Forum Stats
595 Members
27 Forums
2618 Topics
Topic Options
#1413 - 02/03/01 07:52 PM Windward sheeting cars
Has anyone had the experience of installing a Harken Windward sheeting car to the existing traveler on a 81 J30? If so which model is appropriate and what modifications are necssary? Thanks, Paul
Top
#1414 - 02/03/01 08:21 PM Re: Windward sheeting cars
Ed Austin Offline
Loc: New York, NY
I used a Harken mid-range windward sheeting car with the low profile track. The difficult part was filling the recessed part that the original traveller mounts in. I used a piece of teak to fill the space, but it needed a bunch of sanding to account for the inconsistent shape. Also, I heard you can buy Harken track with holes that match the original spacing to save some effort.
Ed Austin
Chinook
Top
#1415 - 02/04/01 04:31 PM Re: Windward sheeting cars
Steve Sullivan Offline
Loc: Pella, Ia.
I also have an 81, #311, and installed a windward sheeting car last year. I used a Model 1575 Mid-Range car, Model 1511 Hi-Beam Track with end trim caps, and 1516 Mid-Range Traveler controls to set it up with a 4:1 ratio (all Harken). The Hi-Beam track uses bolts slides so you can match your existing bolts holes. I can't remember exactly but you use only seven bolts or so, far less than the original installation. The other thing you'll need to do is raise the track approximately 1/2" to provide adequate clearance for the travreler car. I used a 1/2" thick piece of Starboard plastic (you could use a piece of teak) under the Hi-Beam track. Not only did it raise the track it covered the unused holes. One final item, I used a continuous traveler line of 3/8" Sta-Set attaching each end to the traveler controls. You need about approximately 30'. There is a good article by Rob Van Name on the Class web site, it further explains the process. Hope this info helps!!
Top
#1416 - 02/04/01 09:12 PM Re: Windward sheeting cars
John Colpitts Offline
Loc: Halifax Nova Scotia, Canada
We purchased the med-range Harken windward sheeting "kit", I don't recall the part number. The "kit" (I think that is what they call it) includes everything but the new traveller car. The kit holes are about 1/16 off the alignment of the original equipment car, but a minor adjustment to the holes (with a tungsten-tipped drill), and it was a bolt-on item. We removend the cleats the pulleys from the old arrangement, and mounted the pulleys on the end of the existing track to give 4-1 purchase. We ahve raced the boat constantly (~50 races/yr) and the travellet hads worked flawlessly, provide it is well lubricated. One of the best upgrades we made.
John in Halifax
# 256, "Shadow"
Top
#1417 - 02/05/01 09:36 AM Re: Windward sheeting cars
John McArthur Offline
Immediate Past President, LIS District Governor
Loc: Stratford, CT USA
Check the Articles of Interest in the Web Site. There is alot of good information there.
Top
#1418 - 02/05/01 07:19 PM Re: Windward sheeting cars
Thanks for all the info on the traveler mods. I realized after the posting that there was info on the subject right in the Articles of Interest. I like the prospect of using the Harken Kit and the original traveler car. Thanks again, Paul
Quote:
Top
#1419 - 02/06/01 08:38 PM Re: Windward sheeting cars
Hi John, thanks for the info. Do you have to add a spacer under the original traveler track as on the complete modifications mentioned on other replies to my original question. Thanks, Paul
Quote:
John in Halifax
# 256, "Shadow"
Top
#1420 - 02/12/01 03:11 PM Re: Windward sheeting cars
Our objective was to not remove the original track - so no, we did not put a spacer under the track. The car and traveller kit will clear the bridgedeck, but you do have to be careful to keep the traveller lines clear - they love to get jammed between the car and the edge of the seats.
John in Halifax
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
1 registered (Bob Rutsch), 7 Guests and 4 Spiders online.
X48 vs J30
Running the spin halyard
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Deck Square Footage?
by JeffSmithNJphoto
05/15/12 09:16 PM
Board Rules · Mark all read
