If you are plugged in at a marina and the system is properly grounded, the answer is you need some protection. Shaft zincs can be augmented with a "
fish anode" you drop over the side. The problem is that others near you in your marina may have leakage currents that end up causing a problem on your boat. If you are in fresh water you can use aluminum or magnesium instead of zinc.
