Re: Cutlass Bearing
[Re: Phil]
#14538
03/04/13 08:12 AM
03/04/13 08:12 AM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
Herb
I had mine replaced several years ago The yard ordered it so I'm not sure of the part number let me check with them and see if I can get you a part number
Charlie Stoddard Falcon #229
Re: Cutlass Bearing
[Re: Black Knight]
#14540
03/04/13 10:20 AM
03/04/13 10:20 AM
Posts: 203 Oxford, MI
Conundrum
Oxford, MI
I replaced my Cutlass bearing on my 1984 1 in shaft Invoice says Betta Bearing $72.66 I think they would have yours. Marine Machining and Manufacturing., LLC 33475 Giftos Clinton Twp, MI 48035 586-791-8800 FAX 586-791-8803 www.marinemachining.com
52
guests, and 1
spider. |
