978,305 Dacron Main
163,315 Ananda's Refit
Cutlass Bearing #14533
03/03/13 01:28 PM
03/03/13 01:28 PM
Panama
Black Knight Offline OP
Panama
Can someone tell me the type or product number of the cutlass bearing I should order and where I can order it by email in the US. I have a 3/4 inch shaft on a 1980 J30, hull 237? Thanks mucho.
Herb Clifton, hull 237, Black Knight, Panama
Re: Cutlass Bearing [Re: Black Knight] #14534
03/03/13 07:30 PM
03/03/13 07:30 PM
Herb - I have a 1" shaft on Rhapsody so can't help with the part number. I think Charlie Stoddard just bought a new cutlass bearing for Falcon. I'll email him and ask him to post info here.
Re: Cutlass Bearing [Re: Black Knight] #14535
03/03/13 09:26 PM
03/03/13 09:26 PM
Richmod, VA
Phil Offline
Phil  Offline
Richmod, VA
My Cutlass Bearing needed to be replaced last year, and I needed to have one machined.
Re: Cutlass Bearing [Re: Phil] #14538
03/04/13 08:12 AM
03/04/13 08:12 AM
Barrington, RI
cstoddard Offline
cstoddard  Offline
Barrington, RI
Herb
I had mine replaced several years ago The yard ordered it so I'm not sure of the part number let me check with them and see if I can get you a part number
Charlie Stoddard
Falcon #229
Re: Cutlass Bearing [Re: Black Knight] #14539
03/04/13 08:29 AM
03/04/13 08:29 AM
I've attached the Durmax spec sheet for cutlass bearings. The 1" shaft on Rhapsody uses bearing code BACK (Metallic) or BABE (non-metallic) and was cut to length. Once the proper size is known for the 3/4" shaft, you can use this to search for a vendor to buy from.
Bronze Sleeve
Non-Metalic Sleeve
Re: Cutlass Bearing [Re: Black Knight] #14540
03/04/13 10:20 AM
03/04/13 10:20 AM
Oxford, MI
Conundrum Offline
Conundrum  Offline
Oxford, MI
I replaced my Cutlass bearing on my 1984 1 in shaft
Invoice says Betta Bearing $72.66
I think they would have yours.
Marine Machining and Manufacturing., LLC
33475 Giftos
Clinton Twp, MI 48035
586-791-8800
FAX 586-791-8803
www.marinemachining.com
3/4" Shaft: Cutlass Bearing [Re: Conundrum] #14542
03/05/13 12:48 AM
03/05/13 12:48 AM
Herb,
I found this old post the indicates the outside diameter of the cutlass bearing for the 3/4" shaft is 1.25", which is the same OD that the 1" shaft has.
The cutlass bearing codes for the 3/4" shaft are:
Bronze Sleeve - ABLE
Non-Metalic Sleeve - ALDA
Re: 3/4" Shaft: Cutlass Bearing [Re: Rhapsody #348] #14543
03/05/13 02:56 PM
03/05/13 02:56 PM
Panama
Panama
Thanks Bill and everyone .... I now know more about cutlass bearings than I ever thought I would .... I have an email request into one of the vendors mentioned in the posts and am waiting for a product number and vendor from one of the members of this forum. .... Herb Clifton
Re: 3/4" Shaft: Cutlass Bearing [Re: Black Knight] #14544
03/05/13 03:08 PM
03/05/13 03:08 PM
Panama
Panama
Changed my mine .... I just ordered it from West Marine from Bill's old post reference. Mission accomplished .... thanks mucho to everyone .... Herb Clifton
