LChristy
Loc: Annapolis, MD US
The J30 Class Rules have been changed as of January 1, 2003. These changes include;
6.7 CREW LIMIT
The maximum crew weight (in swimming apparel) for one design racing is 1400 pounds with no limit on number of crew. If the sailing instructions require a weigh-in prior to the start of a regatta a boat complying with the weight restrictions at weigh-in shall not otherwise be subject to a weigh-in during or after the regatta, except for weighing substitute crew. The crew limit may be waived or modified by local fleets or event organizers for any event other than the North American Championships or the Mid-Winter Championships.
6.4 SAFETY GEAR AND EQUIPMENT
In addition to safety equipment required by Coast Guard and local regulations, the following equipment shall be carried onboard for one design racing.
- Permanently installed navigation lights in working order - Fixed non-electric compass - Fog horn - Two water resistant flashlights - Two fire extinguishers of type and capacity required by local and Coast Guard regulations - PFD for each member of the crew - One throw-able lifesaving device within reach of the helmsman - Equipment capable of disconnecting or severing the standing rigging - First Aid Kit and manual - Five soft wood plugs of size to fit each below waterline through hull fitting - One permanently fitted manual bilge pump operable from the cockpit with all hatches, lockers and companionways closed. If handle is removable, it shall be tethered to prevent loss - Two rigid buckets with lanyards having a minimum capacity of two gallons each - One anchor and rode (further description required) - Radar reflector (with minimum diameter of 8-10”) - Depth sounder (or lead line) - Radio receiver capable of receiving weather bulletins - Safety harnesses for at least 50% of crew - Distress signals meeting USCG requirements - Heaving line (minimum 50’ length) within reach of the helmsman - For local and national events the notice of race and sailing instructions may require additional safety equipment.
We will try to get a set of the current class rules and specifications including these changes on the web site as soon as possible.
Larry Christy J30 Natiional Class Measurer alchristy@comcast.net 410-267-8990
Joe Ruzzi
Loc: Arnold, MD
I'm bringing this thread back to the front because the required equipment list will be inspected for the North American Championship Regatta. If you are planning to attend, you should make sure that you have these items onboard when the measurement committee comes to inspect your boat.
