If RigRite no longer carries them then I'm assuming it's game over and one has to go the DIY route — correct? Also, my boat is missing its mast partners. These, I assume are a make on the spot kind of thing?
Re: NEED MAST BOOT.
[Re: Walter]
#14716 05/04/1311:50 PM05/04/1311:50 PM
