Re: head sink
[Re: whitedolphin]
#10168
09/01/10 01:57 PM
09/01/10 01:57 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
I could not find one either. I took a piece of Starboard and cut out a piece that fit over the old holes and big enough to fit under a new faucet. Then screwed it in place. Then I re-drilled it to fit the new faucet. I also put a bit of Silicon sealant under it so water would not leak through.
Re: head sink
[Re: Chris623]
#14733
05/13/13 08:08 AM
05/13/13 08:08 AM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
Should be able to find it at home depot 1 1/4 is a standard under sink size they make them in brass chrom'd and in plastic
Charlie Stoddard Falcon #229
44
guests, and 14
