Re: Main Sail Material
[Re: Rhapsody #348]
#15069
08/12/13 07:31 PM
08/12/13 07:31 PM
Posts: 88 Belmont, MA
Georges
Belmont, MA
Bill, I am interested by the Hood woven vectran proposal. Did you end up ordering and using this vectran woven sail? After four year what is the verdict?
[Re: Russ Atkinson]
#15081
08/18/13 10:38 AM
08/18/13 10:38 AM
Georges
Belmont, MA
Thanks Bill, Doyle - close by - seems to have a similar offer will check with them too.
[Re: Georges]
#15082
08/18/13 10:53 AM
08/18/13 10:53 AM
Posts: 91 Salem, MA USA
Luke Buxton
Salem, MA USA
I would also look into a north radiant cloth for a main or a 3dl marathon sail.
Luke Buxton Evelyn Hull #179
[Re: Russ Atkinson]
#15467
02/19/14 07:33 AM
02/19/14 07:33 AM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
I just looked and this topic has the most views of any on the J/30 Forum. Much time has passed since Russ posted in 2008, and we have enjoyed having Wildcat at the NAs in New Orleans in 2012 and Barrington in 2013. Now for the question / continuation of this thought Russ proposed. Does the class want to: 1. Keep the main sail restriction "as-is" with Dacron. 2. Update the class rules to allow any Woven material (e.g. the main I tried from Hood Sails with Vectron threads woven in the fibers) 3. Remove the restriction on mainsail materials. When you post your response, please provide the rationale for your decision.
[Re: Russ Atkinson]
#15472
02/20/14 01:34 PM
02/20/14 01:34 PM
Posts: 80 Melbourne, FL
sailon
Melbourne, FL
I use my boat for both day sailing and cruising. When I look at the overall value of the sail, the ability of a racing sail to "retire" into a life of cruising is attractive. I have owned MANY laminated plastic, and Dacron sails. When the plastic sails reach end life, they typically are a delaminated mess. Dacron sails, while they don't hold their shape as well as laminated sails do, are still perfectly fine for cruising, in fact I am sure I still have the original Dacron mains in my loft that would work just fine for daysailing. Soooo, points in favor of Dacron. On the other hand, the current methods of giving Dacron some rigidity require the application of a stiffener, that makes handling of the sail difficult, and can even risk damage to the cloth if a wrinkle is not removed carefully. If a woven material can be incorporated that provides the stiffness of impregnated Dacron, is easy to handle, and has a "lifevalue" similar to Dacron cloth, that would carry my vote going forward.
39
guests, and 1
spider. |
