Class Genoa
#15249
10/14/13 11:42 PM
10/14/13 11:42 PM
Posts: 114 Richmod, VA
Phil
Richmod, VA
I am about to order new #1 for my boat, and received the following quotes at the Annapolis Boat show:
Neil Pryde Sails - Vectrix Sport String Saill, Membrane construction, made out of Vectrix Technora - $2,346.82
Quantum - Fusion M Class Sail, Membrane construction, madeout of Black Aramid yarns with Yellow Aramid fibers between polyester films - $3,589.38
Ulman Sails - Technora fiber path -$2,492, (recommendedboption) or Aramid X-tech $2,067
North - 3DL 680 thermo molded made out of Aramid/cCarbon (70% / 30%) -$2,846.40
Could not find a U/K booth at the event, butwill try to get a quote from them as well. U/K, North & Quantum seem to be what boats here on the Chesapeake use, but I am wondering if any one hasany experience with Neil Pryde or Ulman?
guests, and 1
spider. |
