Re: Main Sail Material
[Re: Russ Atkinson]
#15478
02/21/14 10:17 PM
02/21/14 10:17 PM
Posts: 135 Summit, NJ
Michael L
Summit, NJ
I'd say open up if it makes the boat more competitive in PHRF (along with other restrictions such a spinnaker cloth minimum). If however it were to lower the PHRF, then not worth the effort.
Michael
[Re: Russ Atkinson]
#15481
02/24/14 01:39 PM
02/24/14 01:39 PM
Posts: 393 Rockwood, MI, USA
Russ Atkinson
Rockwood, MI, USA
My views are well documented and have not changed but I will not engage further in this discussion. Wildcat is committed to racing one design and thus we've made the decision to invest in a one design main, along with a trailer (so we can travel to one design events), etc. For PHRF we continue to use a laminated sail. And yes, it is an expensive commitment to have two sails.
Michael, sail cloth is not at all factored into PHRF ratings unless the sail material is a violation of class rules. Some areas give a "one-design" PHRF rating for the J-30. Non compliance to one design configuration is a 3 second penalty - but not directly related to sail material. To be specific, if the class approved a non-Dacron main, the boat would then be class compliant and still be able to sail with a class PHRF rating
[Re: Russ Atkinson]
#15486
02/24/14 08:01 PM
02/24/14 08:01 PM
Michael L
Summit, NJ
Russ,
My point exactly. If the Class allowed laminate, then PHRF shouldn't change.
Anything to add competitiveness to our boats in a PHRF fleet has only upside from my perspective. Highest on the agenda however is the restriction on minimum spinnaker cloth weight.
Michael
[Re: Russ Atkinson]
#15488
02/24/14 08:50 PM
02/24/14 08:50 PM
Posts: 2,668 Portsmouth, RI
Rhapsody #348
For what it's worth, in PHRF Narragansett Bay, there is no change in rating due to sail cloth, only for sail size. I asked this question for both the main and spinnaker. I bought a 1/2 oz spinnaker that is the same size as the class spinnaker. It works great in light air. In PHRF-NB area there is no reason to make the 1/2 oz spinnaker OD class legal.
Re: Dacron Main
[Re: Russ Atkinson]
#15613
04/30/14 10:56 AM
04/30/14 10:56 AM
Posts: 10 Fairfield,CT
Defender
Fairfield,CT
Hi I have to agree.....I don't class race but I do like PHRF. I don't have a Dacron main and I don't miss out much on that.... Perhaps because I don't race one design I am the one of the last to speak out about such things. I do wish to support the position that Russ has taken....I agree with him in principle. My non Dacron main needs replacing finally anD I will look to newer technology materials as Dacron is more suited to cruising and antiquated notions of history in my view..... In Southern Connecticut and western L.I. Sound the J 30 has always been a great class and it continues to be so...thanks to CPYC and others,albeit it may be losing ground due to other advances in technology, meaning the J 70's ... a class that proliferates like beneficial microbes in the garden. Meanwhile a class that is losing participation might want to be more accommodating. Perhaps for that reason the board will need to lighten up down the road....? who knows. I am a beer can racer , perhaps a mere novice. I only weighed in because I think the debate is useful. I encourage others to chime in as I am certain there are many factors we have yet to consider. PLEASE CONTINUE THIS DISCUSSION Good luck Barry Butler DEFENDER Fairfield CT
34
guests, and 1
spider. |
