Could someone identify these spreaders? Is this the Hall Spars fix? Some other modification?
There doesn't seem to be a bracket, though clearly the spreaders are bolted to some sort of internal structure (see shadow under tape). I'm hoping it's a through-bar retrofit that eliminates the stock spreader/mast failure issue.
EDIT: Still working on photo... standby
EDIT 2: Got it.
