Topics3,768
Posts18,394
Members927
Most Online223 Dec 17th, 2019
Re: Mainsail options 2014
[Re: Jangles13]
#15522
03/10/14 06:50 PM
03/10/14 06:50 PM
Posts: 26 Maine
Jangles13
Maine
For anyone looking, these are the prices I collected, valid for roughly 30days:
North - Nordac ND78HA (7oz) $2678 Radian NDR75 (tri-radial) $3428 3DL 600 Aramid $5710
Quantum - Contender 7oz $3270 DP 300 SF HTP+ $3450 MR3000 Poly (membrane) $4140 DP Flex19 Poly (tri-radial) $3347
UK - DP 280 AP 6.5 $3124 DP 280 AP HTP $4575 Tapedrive Silver $4234
Doyle - DP 300 SF HTP $3470 DP Flex 16 Poly (tri-radial) $3095
Haarstick - Challenge 7.62 VF $2340 DP 280 AP HTP $2690 DP Flex 15 Stealth (tri-radial) $3500 Loadpath Carbon (membrane) $4750
These are standard build; loose foot, reef, cunningham, full-top, luff cords, tell tales, draft stripes, numbers, ties, bag, etc. Quantum had boat-show promo that was good for a discount, but it has since expired. A couple of the lofts lowered when I dug a bit deeper, but I didn't post any of the reduced pricing, as I suspect it's case-by-case.
EDIT: I also checked a local loft and FX Sails; both were less than anything listed above for crosscut dacron, but I don't have those quotes in front of me.
37
guests, and 0
prebend
by Claribertz. 12/30/20 03:43 AM
