• Home
  • Class
    • Membership Application
    • Board of Governors
    • History
    • Contact Us!
  • Calendar
  • Fleets
    • Directory
    • Districts
    • Teams
  • Forum
  • Info
    • Official Specifications
    • PHRF Rating
    • J/30 @ J/Boats.com
    • Why Own a J/30?
    • J/30 Drawings and Files
    • Diesel Engine Maintenance
    • Articles of Interest
      • J/30 Rigging Information
      • J/30 Spreader Brackets
      • J/30 Rig Tuning
      • J/30 Crew Assignments
      • Cruising Your Racing J/30
      • J/30 Trailering
      • Building a Parking Sail
      • Barient Winch Information
      • Painting Your J/30
      • Shaft Log Replacement
  • Market
    • For Sale
    • Wanted
    • Equipment Suppliers
    • J/30 Apparel
    • J/30 Online Store
  • Photos
  • Regatta
2012 J/30
North Americans
October 18-21
New Orleans YC
New Orleans YC
2012 J/30 SNE
Regionals
July 21-22
Newport YC
Newport YC
2012 Cedar Point OD
June 2-3
Cedar Point YC
Cedar Point YC
Active Topics
Active Posts
Unanswered Posts
Advanced
You are not logged in. [Log In] J/30 Class Association » Forums » J/30 Forum » The Boat, Sails and Equipment » Blisters Blisters Blisters!
May
M Tu W Th F Sa Su
Bob Rude
595 Registered Users
j30news
(Views)Popular Topics
Dacron Main 97922
Northwest one-design 55235
J30.org Web Page 20724
Southern Straits 13273
Forum Stats
595 Members
27 Forums
2619 Topics
Topic Options
#1557 - 09/28/07 06:27 PM Blisters Blisters Blisters!
HHSA Offline
Loc: Henderson Harbor N.Y.
Velocity Girl came out of the water on lake Ontario and she has some serious blistering issues. When I bought her this spring she had some blisters which I planned on fixing this fall. When I hauled her this week she came out looking awful on the bottom. I am planning on sanding and grinding the bottom this fall and letting her dry out this winter. I am looking for advice or tips on materials to use and process. I feel like I might be looking at grinding alot of bottom off behind the keel. I am a do it yourselfer on a budget so any tips help would be appreciated! I want to get her light smooth and fast for next season.
Thanks
HHSA
Velocity Girl #278
Top
#1558 - 09/29/07 12:23 PM Re: Blisters Blisters Blisters!
R II Offline
Loc: Bellevue, WA, USA
Quote:
When I hauled her this week she came out looking awful on the bottom. I am planning on sanding and grinding the bottom this fall and letting her dry out this winter. I am looking for advice or tips on materials to use and process. I feel like I might be looking at grinding alot of bottom off behind the keel. Velocity Girl #278[/B]
From my experience with Rauzer II #448, the only area that showed blisters was where the core was wet underneith. You may have a larger problem than you think. Sorry to be the bearer of bad news but these boats tend to develop areas where the balsa core soaks up water from any number of sources. You can grind, sand and patch the blisters this year and find a whole new batch next year. I would suggest going over the area with a good moisture meter to determine the size of the effected area, identify the source of the water intrusion and go from there. There are several posts on repairing wet core on this forum if that is what it comes to. Good Luck, AC
_________________________
AC
Top
#1559 - 10/02/07 12:34 PM Re: Blisters Blisters Blisters!
Geoff Offline
Loc: Olympia, Wa
Quote:
I don't know if this is always the case. A friend recently purchased a J30 with a similar problem-blisters everywhere (mine is close but not as bad). He ground them out and after a week of drying the moisture meter readings have gone down considerably. We drilled test holes into the core in areas where the moisture meter pegged (also the areas of highest blister concentration) and the core is solid and dry. Excessive blistering can be the result of wet core issues, but It doesn't always mean you have a wet core. We are currently drying out the boat with a process called water out http://www.waterout.com/ that is great for drying flood damaged houses. It should take a couple of days and I will post the results if people are interested. Knowing that the blisters are not the result of a wet core, we will dry the bottom, repair the blisters barrier coat and paint. Hopefully this will prevent future blistering. If it works I will try it on my boat!
Geoff
Krru #413
Top
#1560 - 10/02/07 03:34 PM Re: Blisters Blisters Blisters!
Class Co-President
Loc: Portsmouth, RI
I just looked at their web site. Looks like it's easier to see how this applies to a building. How do they do a boat? Do they build a cocoon around the hull?
Bill Kneller
Rhapsody J/30 #348
Projects & Documentation
Top
#1561 - 10/06/07 06:33 PM Re: Blisters Blisters Blisters!
Geoff Offline
Loc: Olympia, Wa
Quote:
The system is designed to dry buildings and houses. We are trying this as an experiment and so far the results seem good.
We have tented the boat (like you would to spray the bottom. We are drying localized areas of wet core by drilling holes and monitoring moisture with a meter. Looks like it should take 4 or so days to completely dry. I will post results depending on the success.
Top
#1562 - 10/08/07 04:54 PM Re: Blisters Blisters Blisters!
HHSA Offline
Thanks to all for the info. I had the hull core tested before I bought the boat and it was dry this spring. I am investigating other caused and have been looking for "leaks" in the hull. So far so good on the "leaks". All your info seems great. I am interested in all the info you have supplied. I will keep you posted on Velocity Girl's progress. She is a good boat and I am looking forward to getting her up to speed for next summer. The season is too short up here on Lake Ontario.
Thanks
HHSA
Velocity Girl
#278
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  David Erwin
Print Topic
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Who's Online
1 registered (jezebel447), 10 Guests and 3 Spiders online.
X48 vs J30
Running the spin halyard
by Rhapsody #348
05/21/12 09:34 PM
by Cap'n Vic
05/21/12 08:54 AM
by Cap'n Vic
05/18/12 08:11 PM
Carbon Spinnaker Poles
by Cap'n Vic
05/18/12 08:05 PM
by JeffSmithNJphoto
05/18/12 07:22 AM
Grease Rudder Pintles?
by JeffSmithNJphoto
05/18/12 07:08 AM
by David Erwin
05/18/12 12:36 AM
by Cap'n Vic
05/17/12 08:21 PM
by Alan Veenstra
05/17/12 10:56 AM
Yanmar 2QM Engine Mounts
by CAN106
05/16/12 04:19 PM
Board Rules · Mark all read
