978,305 Dacron Main
163,315 Ananda's Refit
stuffing box and packing material #15609
04/26/14 11:22 AM
04/26/14 11:22 AM
Iowa City IA
Phantom364 Offline OP
Iowa City IA
I'm replacing the cutlass bearing and was going to replace the packing material in the stuffing box. Since I have the shaft out of the boat, I was able to look at the stuffing box knot, it appears that there was no packing material in it only a white nylon washer. I can't imagine this is a dripless seal. Before I added packing flax I wanted to check to see if this might be a dripless or if the packing material was never in there. I never had any leaking. Phantom has a 3/4 inch shaft.
thanks for the help
Re: stuffing box and packing material [Re: Phantom364] #15610
04/27/14 01:40 PM
04/27/14 01:40 PM
Iowa City IA
Iowa City IA
never mind. On further examination it was the old worn packing
