Re: Engine Trouble
[Re: JBiermann]
#15683
06/14/14 11:20 PM
06/14/14 11:20 PM
Posts: 164 Portland, ME
JBiermann
Portland, ME
It happened fairly quickly, engine running smooth at 1900, making about 5.5 kts. Then I think I heard a subtle change in the engine tone, it seemed slightly more tinny. 30 seconds later, engine revs dropped, engine died and thats where I am now.
Now I'm thinking that maybe my exhaust elbow is blocked up and by running the engine a little higher than normal maybe it backed up and killed the engine? If this happened, that do I need to do to get the engine running again (once I replace the part?)
35
guests, and 1
spider. |
