978,284 Dacron Main
163,310 Ananda's Refit
Page 4 of 4 1 2 3 4
Re: Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: Conundrum] #13469
04/27/12 07:58 PM
04/27/12 07:58 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
continuing this discussion ... So OK if we acknowledge a .005 working figure ...
does that actually mean .005 between pin and rudder hardware or just in the hole and pin size?
working on rudder this week and looked at pins from 1984 late.
1. Pins in rudder hardware barely have enough slop for two strips of cheap copy paper say each sheet is .004 but only using narrow strip ... so say free space is about .008
I agree that the problem is not in the rudder hardware or pins.
2. the pins show a tiny amount of groove and using copy paper as an measuring tool ... I'm saying the groove is .002
3. the bottom pin is more worn that the top pin but not a lot.
[can tell the difference because the bottom of the bottom pin is corroded]
4. the real problem must be the gudgeons. where I am seeing over 1/8 in. of slop at the bottom one.
5. I am not going to do anything to "correct" this other than putting the bottom pin in the top gudgeon when i put the rudder back on Sunday.
eIMG_0677.jpg [36.23 KBytes] - (1315 downloads)
Pintle pins J30 with 28 years of use.
eIMG_0667.jpg [44.22 KBytes] - (1107 downloads)
clearance between pintle pin and rudder hardware J30 at 28 years ...
eIMG_0679.jpg [31.3 KBytes] - (1052 downloads)
bottoms of pins showing corrosion on the lower one
Re: Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: Cap'n Vic] #13473
04/28/12 07:29 AM
04/28/12 07:29 AM
Key West, & Charlotte, NC
lumpy Offline
lumpy  Offline
Vic,
Ted Kaperonis, (specialK) tkaper6862@aol.com, had a very good looking set of pintles and gudgeons that he was selling from Hoodlum. They were from a freshwater boat that spent a lot of time on a trailer, I saw them about a year ago and I remember tthey looked in "like new" condition.
Lumpy
Scott Davis
Night Nurse #363
Re: Updated Drawings for J/30 Rudder Pintles & Gudgeons [Re: lumpy] #15690
06/15/14 09:03 PM
06/15/14 09:03 PM
Chile
Aluminio Offline
Aluminio  Offline
Chile
Ups! destroyed by mooring line tangled around the rudder during heavy weather.
IMG-20140615-WA0020.jpg [44.74 KBytes] - (954 downloads)
Page 4 of 4 1 2 3 4
0 registered members (), 41 guests, and 14 spiders.
