January
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
cstoddard
Kenpickard, Danproawesome, Don N, George Leese, ShaneKilberg
926 Registered Users
861,380 Dacron Main
131,814 Ananda's Refit
Topics3,768
Posts18,394
Members927
Most Online223
Dec 17th, 2019
Furler line routing #15734
07/06/14 06:36 PM
07/06/14 06:36 PM
Maine
J
Jangles13 Offline OP
J
Maine
Installed a Harken unit this weekend, and will be placing fairleads of some nature for the line back to the cockpit. Wondering how everyone w/furlers have the line run, and what they like or wish were different.
First thought is to run it aft on the port deck using bulls-eye fairleads, mirrored to the spin pole downhaul (downf***er) to a cam-cleat just port of the jib-halyard clutches. Ala J105.
I don't favor running along the lifelines, as crew hiking would interfere and often it's hard to be forward-facing during furling.
Suggestions please...
PS if anyone is aware of an adhesive fairlead product, please tell. I would like to avoid drilling more holes.
Re: Furler line routing [Re: Jangles13] #15737
07/07/14 03:00 PM
07/07/14 03:00 PM
RI
Bob Rude Offline
Bob Rude  Offline
RI
On our boat, Mmmmm, we have a Harken roller furler unit. We run the lines down the inside of the starboard lifelines, terminating about 3/4 ths of the way back to the cockpit...maybe even further. The lines are lead through small Harken bullet blocks. The last block is a larger ratcheted Harken block that is affixed to the forward-most section of the starboard side of the stern pulpit. There is a small cleat affixed to the deck which is used to tie off the furler line. The extra line is coiled and hung on the stern pulpit with a Velcro strap.
Bob Rude
Mmmmm
#352
Re: Furler line routing [Re: Jangles13] #15738
07/07/14 03:38 PM
07/07/14 03:38 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
the biggest problem is clearing the hatch ... before you drill for a fair lead ... we have worked with a small block at the pole foredeck anchor which then went to a small block on a slide on the inner jib track back to a harken 150. I'd vote for the mirror image of the pole downhaul line.
Coming into a mooring I like to have as little in the way of bringing in the pickup as possible ... so line led straight back and then a turn to clear the hatch so we can launch spin without it over the edge of the hatch.
0 registered members (), 37 guests, and 0 spiders.
First cruise
COMPLETE SET OF UPPER/LOWER RUDDER GUDGEONS, PINS $325.00
by Rhapsody #348. 01/16/21 06:55 PM
by B Davis. 01/16/21 03:24 PM
Introduction and Asking for Advice
by neumannaudio. 01/15/21 04:00 PM
Wanted - Triple Deck Organizer - Found One
by B Davis. 01/05/21 03:36 PM
Stern Perch Seats
by Michael L. 01/05/21 09:19 AM
prebend
by Claribertz. 12/30/20 03:43 AM
Winter boat cover
by Gene A Trentham. 12/18/20 03:37 PM
Engine Housing Access Hatch
by Michael L. 12/18/20 03:32 PM
Aluminium Spinnaker Pole
by Michael L. 12/18/20 02:17 PM
