977,800 Dacron Main
163,171 Ananda's Refit
Furler line routing #15734
07/06/14 07:36 PM
07/06/14 07:36 PM
Maine
J
Jangles13 Offline OP
J
Maine
Installed a Harken unit this weekend, and will be placing fairleads of some nature for the line back to the cockpit. Wondering how everyone w/furlers have the line run, and what they like or wish were different.
First thought is to run it aft on the port deck using bulls-eye fairleads, mirrored to the spin pole downhaul (downf***er) to a cam-cleat just port of the jib-halyard clutches. Ala J105.
I don't favor running along the lifelines, as crew hiking would interfere and often it's hard to be forward-facing during furling.
Suggestions please...
PS if anyone is aware of an adhesive fairlead product, please tell. I would like to avoid drilling more holes.
Re: Furler line routing [Re: Jangles13] #15737
07/07/14 04:00 PM
07/07/14 04:00 PM
RI
Bob Rude Offline
Bob Rude  Offline
RI
On our boat, Mmmmm, we have a Harken roller furler unit. We run the lines down the inside of the starboard lifelines, terminating about 3/4 ths of the way back to the cockpit...maybe even further. The lines are lead through small Harken bullet blocks. The last block is a larger ratcheted Harken block that is affixed to the forward-most section of the starboard side of the stern pulpit. There is a small cleat affixed to the deck which is used to tie off the furler line. The extra line is coiled and hung on the stern pulpit with a Velcro strap.
Bob Rude
Mmmmm
#352
Re: Furler line routing [Re: Jangles13] #15738
07/07/14 04:38 PM
07/07/14 04:38 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
the biggest problem is clearing the hatch ... before you drill for a fair lead ... we have worked with a small block at the pole foredeck anchor which then went to a small block on a slide on the inner jib track back to a harken 150. I'd vote for the mirror image of the pole downhaul line.
Coming into a mooring I like to have as little in the way of bringing in the pickup as possible ... so line led straight back and then a turn to clear the hatch so we can launch spin without it over the edge of the hatch.
0 registered members (), 47 guests, and 14 spiders.
