978,436 Dacron Main
163,354 Ananda's Refit
Yanmar 2YM15 Diesel with longer shaft from J/30 also other parts #15456
02/14/14 09:51 AM
02/14/14 09:51 AM
St Augustine, FL
B
Boatguy30 Offline OP
B
St Augustine, FL
I am working with a local marina to dispose of an older j/30. The hull is probably not worth saving, but just before the owner died a few years go he had a NEW 2YM15 Yanmar installed. engine has about 20 hours on it. Still has some of the tags attached.
It appears a longer shaft was fitted as this engine is shorter than the original. This would be included and appears to be 3/4"
Also have good, older Kenyon mast and boom, bow and stern pulpits. Not much else is good. Has a rudder, but I'm sure it's soaked and delamed.
Winches are self tailing, but some of the tailing parts are broken/missing. Maybe the gears and bearings could be spares for someone.
Main thing is to get fair price for the engine as boat has 3 years unpaid dockage $9,000.
Make offer on engine or any parts interested. Can ship engine from St Augustine, FL.
Jeff Goff
904/377/9403
Re: Yanmar 2YM15 Diesel with longer shaft from J/30 also other parts [Re: Boatguy30] #15457
02/14/14 02:02 PM
02/14/14 02:02 PM
Melbourne, FL
sailon Offline
sailon  Offline
Melbourne, FL
Jeff,
Are any of the secondary winches self tailing? Serviceable?
Thanks
Art
321-480-4915
Re: Yanmar 2YM15 Diesel with longer shaft from J/30 also other parts [Re: Boatguy30] #15464
02/15/14 08:36 AM
02/15/14 08:36 AM
St Augustine, FL
B
B
St Augustine, FL
As noted, they are both self tailing barients one winch is mostly complete but part of the upper alloy tailing jaw is broken/missing. The other side appears to have a completely different plastic top jaw and doesn't seem complete either. Both seem to rotate OK so I assume parts are good.
Re: Yanmar 2YM15 Diesel with longer shaft from J/30 also other parts [Re: Boatguy30] #15779
07/24/14 06:30 AM
07/24/14 06:30 AM
Barrington, RI
cstoddard Offline
cstoddard  Offline
Barrington, RI
is the bow pulpit still available
Charlie Stoddard
Falcon #229
Re: Yanmar 2YM15 Diesel with longer shaft from J/30 also other parts [Re: Boatguy30] #15907
10/08/14 06:45 PM
10/08/14 06:45 PM
Fairfield,CT
D
Defender Offline
Defender  Offline
D
Fairfield,CT
Did that j 30 ever get liquidayed? I am in need of a hatch
thanks
Barry 203-615-1100 text cell
Re: Yanmar 2YM15 Diesel with longer shaft from J/30 also other parts [Re: Boatguy30] #16553
11/01/15 09:37 AM
11/01/15 09:37 AM
Chicago, IL
D
deathtrap30 Offline
deathtrap30  Offline
D
Chicago, IL
Jeff,
Do you still have the Amphitrite? Let's catch up.
Alan V 773 791 7923
0 registered members (), 39 guests, and 1 spider.
