977,800 Dacron Main
163,171 Ananda's Refit
Top & Bottom Gudgeons Needed Quickly #15798
08/11/14 10:15 PM
08/11/14 10:15 PM
Atlantic Highlands, NJ
JeffSmithNJphoto Offline OP
Does anyone have them or know where I can get them?
Don't ask...
Re: Top & Bottom Gudgeons Needed Quickly [Re: JeffSmithNJphoto] #15799
08/12/14 08:05 AM
08/12/14 08:05 AM
Rhapsody #348 Online content
Rhapsody #348  Online Content
Try Rig-Rite
Special Gudgeon for 1" Pin: RR 81-78JT:
Special Heavy-duty SS Gudgeon for 1" Pin attaches to Transom with (4) 5/16" bolts. Gudgeon has (2) heavy 1/4" triangular tabs welded to 1/4" base plate. Gudgeon protrudes 2 3/4" (maximum) from Transom, hole center for 1" Pin is 1 3/4" from Transom, clearance between tabs is 2 1/8". Base is 7" wide x 3" high x 1/4" thick with mounting holes on 6" horizontal and 2" vertical centers. As used on J/29F, J/29M, & J/30.
1" Gudgeon Pin: RR 81-78P:
Specially machined 1" Pin with welded tab for use with RR 81-78JT 1" Gudgeon. Pin is (maximum) 3 9/16" long x 1" OD with hole for 1/4" cotter Pin.
Re: Top & Bottom Gudgeons Needed Quickly [Re: JeffSmithNJphoto] #15800
08/12/14 08:30 AM
08/12/14 08:30 AM
Thanks Bill,
I'll give them a call at 9.
Re: Top & Bottom Gudgeons Needed Quickly [Re: JeffSmithNJphoto] #15801
08/13/14 02:10 AM
08/13/14 02:10 AM
Rig Rite never got back to me about availablelity (!) , but a local machinist straightened them & welded the tangs for a very reasonable price.
0 registered members (), 47 guests, and 14 spiders.
