Re: Throttle control removal
#2315
02/03/05 10:49 PM
02/03/05 10:49 PM
I cut it off with a sawsall last year at the suggestion of my yardman. The button had pulled out and the only way to get the boat into neutral was to open the lazarette cover and manually pull back the greasy fitting as for putting it in gear a phillips screwdriver in the hole worked fine. There is a new morse unit that fits in fine and does not require any other that a very minor cable adjustment.
[Re: Trouble]
#15848
09/15/14 10:47 PM
09/15/14 10:47 PM
Posts: 13 Seattle, WA
Derek Storm
Seattle, WA
Following those instructions, I unscrewed the black knob, pulled out the red handle, and loosened (3 or 4 turns) the set screw. This, by the way, takes a 5/32 allen wrench, and has to be done by feel. But the chrome fixture doesn't pull off or even pry off. It seem fixed on the main part of the mechanism. Is this a corrosion issue? I assume you don't have to remove the set screw completely... Any ideas? (not enthusiastic about the sawzall solution)
Derek Storm Outlaw, Hull 144
[Re: Trouble]
#15876
09/26/14 11:55 AM
09/26/14 11:55 AM
Derek Storm
Seattle, WA
A picture (or part description) would be useful. However, my problem is I don't know how to get the original unit out. How did you remove the "shot" throttle/shifter control?
[Re: Trouble]
#15881
09/29/14 09:37 PM
09/29/14 09:37 PM
Posts: 164 Portland, ME
JBiermann
Portland, ME
I had the same issue derek, (have actually rebuilt the throttle control several times at this point), with the set screw out (just remove it completely) you need to pry the fixture off with even pressure on both sides. I used two pry bars against the sides of the cockpit, one on either side and with enough pressure it should pry loose. If you're worried about corrosion, spray a little pb blaster and that should penetrate and lubricate. If you pry on just one side it wont release (or at least it wouldn't for me).
Where did you find a new throttle assembly or are you planning to rebuild it?
[Re: JBiermann]
#15883
09/30/14 12:15 PM
09/30/14 12:15 PM
Derek Storm
Seattle, WA
Thanks. I was only prying on one side,so I will try both and some penetrating oil. I gather there is a close fit between the ss cover piece and the inside shaft. The only thing wrong otherwise is the black neutral knob sticks and is hard to pull out (needs to be pried often). It used to be some WD-40 followed by grease would loosen it up, but no longer. The shifting and throttle work fine. So I figured I would take it apart and see if I can clean up the shaft. If I can't I will look into some kind of replacement. There are side mount throttle/shift gizmos listed in our local marine store catalog. Don't know whether they would work, but I imagine the mechanism is common to many boats.
44
guests, and 14
