Topics3,776
Posts18,429
Members932
Most Online223 Dec 17th, 2019
11/04/14 12:17 PM
11/04/14 12:17 PM
Posts: 125 San Francisco
alx
San Francisco
Honestly, I've been "refitting" since I got the boat. But the past couple weeks I've been working to majorly improve the boat's systems (as opposed to the sailing characteristics). My TODO list is lengthy: - Renew all blackwater hoses and clean the old holding tank.
- Replace the old broken head with an electric macerating unit.
- Renew all freshwater hoses and install a new filter and water pressure pump.
- Replace all freshwater fixtures, new galley sink drain, new head sink.
- Install new propane galley stove.
- Install Espar D4 heater and run ducting to main saloon & v-berth.
- Install a holding plate/compressor refrigeration unit in the icebox.
- Replace old electrical panel and clean up the rats nest of wiring.
- Install AIS splitter/receiver.
- Install new 120VAC system with galvanic isolation and battery charger.
- Replace old clouded windows with new opening portlights.
- Replace head and main saloon 9.5x9.5 hatches with new (v-berth hatch already replaced).
- Re-paint blue accent along main cabin roof.
- Apply Kiwigrip for non-skid for entire main deck.
Progress is already well underway - I'm lucky enough to have my dad visiting from Virginia and helping me with the major tasks. Thus far we've completed the blackwater work (ew), the freshwater work (mostly), and are working on installing the propane stovetop, the Espar heater and the portlights. I'll post pictures as we progress!
Re: Ananda's Refit
[Re: alx]
#15944
11/04/14 12:27 PM
11/04/14 12:27 PM
alx
San Francisco
Lots of pictures from the progress so far: Old head before removal: ![[Linked Image]](https://lh6.googleusercontent.com/-4pJVLCrnJ0I/VE28GCMGQlI/AAAAAAAAlOM/WnQrqKlx-18/s1536/work-2.jpg) Head removed, hoses stuffed with rags: ![[Linked Image]](https://lh6.googleusercontent.com/-zzW1e4NZwVY/VE28HQYN_kI/AAAAAAAAlOk/JBiBHma8lYI/s1536/work-4.jpg) More plumbing removal: ![[Linked Image]](https://lh6.googleusercontent.com/-MtW-7YlY_O8/VE28H3x2nTI/AAAAAAAAlOs/w83KMceUooQ/s1536/work-5.jpg) Holding tank removed from v-berth and cleaned: ![[Linked Image]](https://lh6.googleusercontent.com/-2DJQaWAZa3o/VE28I6uvBHI/AAAAAAAAlO4/G1QpaGlkwGM/s1536/work-6.jpg) New head hoses with new vented loop: ![[Linked Image]](https://lh4.googleusercontent.com/-oLja7xXpoMA/VE28JWceq8I/AAAAAAAAlPA/GEr4L_FEaD0/s1536/work-7.jpg) Holding tank replaced with new hoses attached: ![[Linked Image]](https://lh4.googleusercontent.com/-w-EEEUHC15Q/VE28JpY705I/AAAAAAAAlPE/dsQY80WA-M8/s1536/work-8.jpg) New deck fitting for pump out: ![[Linked Image]](https://lh4.googleusercontent.com/-Q6KNoZeVpb0/VE28DgLY97I/AAAAAAAAlNo/Rfd7DXprW5g/s1536/work-15.jpg) Fitting the new head: ![[Linked Image]](https://lh3.googleusercontent.com/-YRU-0bHmoGs/VE28C7_iB6I/AAAAAAAAlNk/jqUU10UcH-4/s1536/work-14.jpg) New head installed: ![[Linked Image]](https://lh4.googleusercontent.com/-YQXKX7larVU/VE28ExQ3vfI/AAAAAAAAlN4/WBSOyBxV7aQ/s1536/work-17.jpg) New head hooked up (no power yet though!): ![[Linked Image]](https://lh6.googleusercontent.com/-JhrQNJyHu4c/VE28FlSwzUI/AAAAAAAAlOI/9uqKdNxNIJw/s1536/work-18.jpg)
Re: Ananda's Refit
[Re: alx]
#15948
11/04/14 05:10 PM
11/04/14 05:10 PM
Posts: 89 Henderson Harbor N.Y.
HHSA
I feel the same way. Velocity Girl has been a work in progress since I bought her too. I have rebuilt the transom literally all new, fixed coring issues in the deck, regripped, new hoses throughout the boat, done woodwork inside and out, had the boom repaired, new running rigging all the way around, new sails, refit the stainless steel rails and stanchions with all new backing plates, rewired big parts of the electrical system, and barrier coated the bottom all since 2007. I have a list a mile long for this spring too... I feel your pain but they really are great boats play on! Good luck with all your projects!
Canaan Velocity Girl #278
Re: Ananda's Refit
[Re: alx]
#15954
11/06/14 12:51 PM
11/06/14 12:51 PM
alx
San Francisco
Progress continues slowly - the hardest part of this job has been the logistics of all the little fasteners, epoxy, tubes of sealant, and other bits that tend to hold up the works when they run out. There is a chandlery down the street but it's minimally stocked, so weekend trips to West Marine have become the norm. Here's my girlfriend Crystal filling the big deck holes with thickened epoxy: ![[Linked Image]](http://i.imgur.com/KXdvTMQ.png) Applying the Marine-Tex to the windows: ![[Linked Image]](http://i.imgur.com/W9Tg6tO.png) One of two small hatches mounted as the sun goes down. This one ventilates the head compartment (very important!). On the right you can see my terrible mounting job for the spinnaker halyard block from last year, due for relocation as I brilliantly placed it right in the weakest spot of the deck. ![[Linked Image]](http://i.imgur.com/eBeVGiY.png) In the port lazarette, mounting the support brace for the Espar heater: ![[Linked Image]](http://i.imgur.com/hKhA0qg.png) And the exhaust flange location marked on the transom (putting it 20" or so above waterline at 0 deg heel): ![[Linked Image]](http://i.imgur.com/GEnlheh.png) Inspection hatch installed back on the tank with new gasket and all hardware mounted: ![[Linked Image]](http://i.imgur.com/eBthIq7.png) Alex,
Your project progress looks great! I would reassess removing the jib tracks. Even if you don't use them now, they provide much flexibility for sheeting angles and other sails. You can isolate the core and reinstall them. There is no need to leave the jib cars on them if you plan on using the pad eyes. I was never happy with the location of the tracks - they didn't provide any good options for sheeting with my current sailplan (95% blade jib). I'm considering adding a 125% or 135% genoa for lighter air, and I'll likely mount a new track in an optimum location if I go that route.
Re: Ananda's Refit
[Re: alx]
#15955
11/10/14 12:08 PM
11/10/14 12:08 PM
alx
San Francisco
Spent all day yesterday putting this together. From left to right: house battery switch, charging relay, engine battery switch. The house battery runs through a shunt which measures current in and out. One of the white cables carries the remote signals for the switches & ACR, the other carries data for the Vessel Systems Monitor on the new panel (shunt measurements, voltage, and temperature). If there's a problem with any of the remote switch connections, the whole setup can be switched manually with the yellow knobs on the tops of the relays. This replaces my off/1/2/combine battery switch. ![[Linked Image]](https://lh4.googleusercontent.com/-vLf5R8dedck/VGA6DATft5I/AAAAAAAApDI/4p5yW3N1Tgg/w2230-h1256-no/IMG_20141109_200709068.jpg)
1 registered members (Avita),
39
guests, and 0
Deck core
by Phil Spletter. 02/11/21 10:00 PM
